spd87
spd87 New Reader
10/22/23 12:50 p.m.
So far so good. I've driven it everyday and the clean IAC seems to have solved the issue. I'll check back in a month to give it the confirmed fix!
spd87
spd87 New Reader
11/1/23 11:07 a.m.
I started it after running the car a while (engine was warm), with AC on and it was a fairly hot day 85* or so. Car idled roughly at 200rpm for about 10 seconds then caught up and started running fine. Any more ideas? Could it have had bad gas in the past? Semi clogged injectors? It seems to only happen at start up.
mtn
mtn MegaDork
11/1/23 12:54 p.m.
Any codes or pending codes? I had an occasional rough idle, barely rough enough to notice it, on my '96 Miata. That went away when I replaced either the PCV valve or cleaned the EGR valve.
If I'm in your position, I'd be throwing $20 and 30 minutes at the problem in the form of cleaning the EGR valve and replacing the PCV and any hoses associated with the PCV and EGR. I'd also consider a seafoam treatment.
spd87
spd87 New Reader
11/1/23 4:28 p.m.
No codes. Thanks mtn! I'll get on it!
spd87
spd87 New Reader
8/18/24 9:30 a.m.
Hey guys, replaced the PCV and still have idle issues on hot days. Again, it's not every time I start the car, but the hotter it is out, the more likely it is to stumble at idle for 10-60 seconds.
I did an amateur vacuum leak check with throttle body cleaner but no change in revs on any of the hoses.
I will mess with the EGR next.
spd87
spd87 New Reader
8/18/24 11:58 a.m.
Is there a EGR removal and cleaning video or write up for dummies? Looks tough to get to.
I unplugged the EGR and it started right up no issues (except CEL).
outasite
outasite HalfDork
8/19/24 10:40 a.m.
I will just throw this out there. I was experiencing a similar condition with my 99. It was the coil pack. One of the spark plug wires was not making good contact inside the coil tower and had melted the insulator. It was not making contact when cold and sometimes while driving. This created a dead miss condition that could be construed as a rough idle/stumble. Easy to check, remove the wires and using a light inspect inside the towers.
spd87
spd87 New Reader
8/25/24 9:28 a.m.
Time will tell, but I think cleaning out the EGR valve fixed the issue. I just ran the car pretty hard, got it hot, then started it back up. No idle issues. Thank you guys!
FVmHFPobSJjgyRS6KiWDEQCPO9I8W0dpvaQ7hvLgxqhLOlVoodKEMA5fcMluPx1q
