hello all. just got my wife the best van {my} money could buy. a 2000 venture WB edition. its in ok shape, and ive done a lot of work to it, but this has me stumped.
When its just me in the van, it drives fine, no apparent suspension/driveline issues. but, when i pack the wife, the kids and my parents into it with an additional 300lbs of stuff, it has issues. Under acceleration and during a right hand turn, i have a serious vibration coming from the right side. once at speed (any speed from 0-80 mph) its gone, rides just fine. during braking, its not there at all. only under accel or right hand turn. it gets even worse up a grade: like a bridge, during accel, it will damn near rattle your false teeth out.
now, at first i immediately thought wheel bearing. i raised the van, checked the wheels, and the the right side was VERY loose. Ok, no problem, get a bearing. well, i got the bearing, replaced it, and the vibration is still there. its SLIGHTLY better, but not significantly improved. so i pulled the left side, that bearing is new, as are some other parts (tie rod end, LBJ, brakes). It looks as if someone before me had this issue and tried to chase it down and gave up. I can't give up. i need this car and i need it NOW.
i did some online searching, and the two primary answers i found were wheel bearings and CV axles. obviously the WB's are good, so im leaning towards axles. when we did the WB, we did notice some play in the outer axle joint on the passenger side, but it didnt seem like a lot. should there be any play at all? will this play affect anything?
I REALLY need some input, hopefully form guys who have done stuff with heavy GM front drive stuff before. I dont have the $$$ to just throw parts at it, but i need to fix it.
suggestions? input?
Thanks in Advance!
-J0N
