AutoXR
AutoXR HalfDork
1/15/13 8:48 a.m.
I am at my wits end with my truck. It stalled in a car wash, after an hour it started right back up. I have gone through and done the following and now it won't even fire.
Parts replaced Cap, Rotor, Coil, Wires,
Things i checked Spark, rotor orientation, firing order, engine codes, Fuses,
I can spray quick start right down the TB and it won't even fire, not even a sputter.
any ideas greatly appreciated!!!!
GameboyRMH GRM+ Memberand PowerDork
1/15/13 8:51 a.m.
Had a similar problem once, there was a noise filter capacitor on the distributor that was failing.
But if you're getting consistent spark at the plugs then it's probably cursed and the car wash is haunted.
RealMiniDriver
RealMiniDriver SuperDork
1/15/13 8:53 a.m.
Ignition module? I got a free S-truck, because it just died one day, and the guy was tired of nickel and diming it back to life. I got it running, but it shortly died again. My smart wife said it was the ignition module - $26 at Advance Auto Parts. It's a small part the goes inside (underneath?) the distributor.
1/15/13 8:55 a.m.
I also had a similar problem once with a sheared distributor shaft, the shaft would slip, mess up the spark timing, then slip back into the proper position and it would run fine. Giving a strong spark the whole time so it was hard to diagnose.
I berkeleying hate distributors, see why I'm switching to coil-on-plug?
N Sperlo
N Sperlo UltimaDork
1/15/13 8:55 a.m.
Reset the fuel? The inertia switch can berkeley things up sometimes. Just a guess.
dean1484
dean1484 GRM+ Memberand UltraDork
1/15/13 8:56 a.m.
RealMiniDriver wrote: Ignition module? I got a free S-truck, because it just died one day, and the guy was tired of nickel and diming it back to life. I got it running, but it shortly died again. My smart wife said it was the ignition module - $26 at Advance Auto Parts. It's a small part the goes inside (underneath?) the distributor.
^^^^^ This. I have run in ot this severial time.
AutoXR
AutoXR HalfDork
1/15/13 8:58 a.m.
The hall effect sensor was my next guess. I am going to check the fuel pressure @ the schrader tonight.
n9kuodurZ8TMISOkCQqsyristjiDbvcuLUPXPV8CZ2QT84wt7H5A7akowF1GyNc5
