Patrick
3/21/19 7:01 p.m.
Do you have one line going to the rail or two?  I don’t have a 2005 anymore to check.
dean1484
3/21/19 7:01 p.m.
Ok let me go look at mine I am still at the office BRB
dean1484
3/21/19 7:03 p.m.
Covers are on my motor and I dont have tools let me do a bit of google looking
dean1484
3/21/19 7:05 p.m.
dean1484
3/21/19 7:09 p.m.
Wait is yours a 6.0 duramax or a 6.0 vortech?
TRoglodyte
TRoglodyte UltraDork
3/21/19 7:23 p.m.
So now the truck is warm and will not start. Gauge reads 10 lb of pressure at the fuel rail and won't build pressure. On this pickup truck there is a box in front of the fuel tank that has three lines running to it and I can feel one line pulsing. Guess I got to find out what's in that box.
TRoglodyte
3/21/19 7:26 p.m.
In reply to dean1484 :
Vortec in  a sierra pickup, gasburner .
TRoglodyte
3/21/19 7:31 p.m.
Watched that video, I guess the 6.0 Sierra is a unicorn because the fuel pressure regulator is not there on the engine.
TRoglodyte
3/22/19 8:26 p.m.
In reply to Patrick :
One line, driver side
Patrick
3/22/19 8:48 p.m.
Ok.
This guy is painful to listen to but explains it perfectly
https://m.youtube.com/watch?v=Z1_tD-Uc0HA
TRoglodyte
3/22/19 9:09 p.m.
Thanks for that, so it is in the tank and it sounds like I got a faulty unit because tonight I started the truck and it's only running 10 pounds of fuel pressure but the truck still runs?
TRoglodyte
3/23/19 6:53 a.m.
Fuel pressure is still low this morning is there anything that would keep thepump from building pressure besides it being faulty?
doc_speeder
doc_speeder HalfDork
3/23/19 9:33 a.m.
Just an FYI, the Dmax is a 6.6 liter.
Streetwiseguy MegaDork
3/23/19 11:04 a.m.
Here is a couple of options:
First, I would grab my labscope and go to the pump fuse to check for voltage and amp draw with the pump running. Then I would voltage drop the power and ground sides of the wiring to confirm which segment has a problem, if any. Following confirmation of the electrical continuity, I would compare amperage draw to pressure created, and decide whether there is a mechanical problem in the pump, either an internal leak in the module, or an issue in the pump.
Or, I might pay somebody who knows how stuff works.
dean1484
3/23/19 11:12 a.m.
When you google the part there are a lot of listings for a 6l  duramax for that year that obviously has a completely different fpr
TRoglodyte
3/23/19 4:45 p.m.
In reply to Streetwiseguy :
If I knew of such a person I would certainly let  that individual fix it.-
TRoglodyte
3/23/19 5:31 p.m.
Could you enlighten me on why an OBD2 port would fail? I have tried two different code readers and it shows nothing
SkinnyG
SkinnyG UltraDork
3/23/19 6:57 p.m.
Doesn't GM's OBDII port share the same fuse as the radio or heater or something?
TRoglodyte
3/23/19 8:10 p.m.
I was wondering about a blown fuse but everything else seems to work lights, radio Etc.
TRoglodyte
3/24/19 6:37 p.m.
In reply to SkinnyG :
Found it, you are correct,lighter fuse. Thank you!
TRoglodyte
3/25/19 7:32 p.m.
What should the amp draw be on a fully loaded pump in static position all injectors fully loaded both rails? On a single return system
3/25/19 8:22 p.m.
Not sure what you mean.  System pressurised, engine not running, zero.  producing 60 psi with the engine running, kinda sixish amps maybeish.  Two isn't enough. 12 is too much, I think.
Lr9BQiK7GFtf9c6C3wcb6BI4Pe0sKCpxeek6zfidQuduldTpLHZYsbTzjdi8GrYc
