doc_speeder
doc_speeder New Reader
3/16/09 8:26 a.m.
Is there anything common with a 4" x 4 bolt wheel to be had from the junkyard? I just picked up a little trailer for nothing and it has those stupid tiny 8" wheels on it. I'd rather get some cheap 13's, 14's etc.
mw
mw Reader
3/16/09 8:31 a.m.
Other trailers?
4x100 is really close and would probably bolt on.
aeronca65t
aeronca65t Reader
3/16/09 8:37 a.m.
Sprites and Midgets. 13" X 4.5"
Dime a dozen in my area.
Also, Chevy Vegas and similar (but getting harder to find)
Do not use 4 X 100mm for anything other than rolling around in your yard.....won't center correctly, might come loose quickly and could cause lug or wheel failure.
Keith
3/16/09 10:14 a.m.
I've got a set of four 12" Minilites with that pattern if you're interested.
sachilles
sachilles Reader
3/16/09 11:17 a.m.
northern tool and the like have new 4x4" trailer wheels for cheap. I have set of 13x5.5 inch cheviot wheels from my mini that i've been trying to sell. They are too heavy for autocross, but would be fine for a trailer, but I'd want to sell all four. http://www.minimania.com/web/threadid/89918/msgthread.cfm I could be persuaded to trade for various items including 4x100 13 inch wheels, honda b series shift linkage, gauges and various other honda parts I need for my vtec mini
914Driver Dork
3/16/09 11:20 a.m.
mw wrote: Other trailers? 4x100 is really close and would probably bolt on.
You would think the difference is insignificant.
4 inches = 4.000
100 mm = 3.9375
It's a half of lug bolt diameter off no matter how many times you spin it around. Won't work.
Poke around here: http://www.willysoffroadsupply.com/Wheel_Spacer_Chart.html
Dan
stumpmj
stumpmj Dork
3/16/09 12:11 p.m.
The local trailer place by me sells steel wheels new for $10-$20. I'll bet there's one by you too that has the same wheels for the same price.
Walmart and similar places sells the wheels with tires mounted for <$50. So does Harbor Freight.
I doubt junkyard scrounging would be much if any cheaper.
stuart in mn
stuart in mn Dork
3/16/09 12:16 p.m.
Another vote for Northern Tool. The last time I went there looking for trailer tires, it was just as cheap to buy a set of wheels with the tires mounted on them. They have larger sizes, 10", 12", 13".
Jensenman
Jensenman SuperDork
3/16/09 1:14 p.m.
On this subject: there's someone who makes an offset lug bolt? and I could use some for a possible upcoming project. Anybody have a line on those things?
sachilles
sachilles Reader
3/16/09 1:20 p.m.
I think fiat x 1/9 folks use offset bolts at times as their wheel fitament is a less popular size. I bet someone with an x might know of a source.
mw
mw Reader
3/16/09 1:44 p.m.
You would think the difference is insignificant. 4 inches = 4.000 100 mm = 3.9375 It's a half of lug bolt diameter off no matter how many times you spin it around. Won't work. Poke around here: http://www.willysoffroadsupply.com/Wheel_Spacer_Chart.html Dan
Actually it's I've done similar in the past. 4" = 101.6mm So 1.6mm diffenrence in the diameter. As long as you use hub centric rings, it should not be a problem. I worked at a wheel and tire place and we got a great deal on 400 wheels that were 4x98mm bolt pattern. They would slide onto the studs of a 4x100 car. We made machined up some hubcentric rings on them and sold all 400 wheels. We never had anyone come back complaining about shaking or shimmy's and these were mostly on hondas where you would definitely notice. If you did the same on a trailer I bet there would be no problem. I've also done the same and put 4x4.25" wheels on my 4x110mm RX7
44Dwarf
44Dwarf Reader
3/16/09 7:46 p.m.
Jensenman wrote: On this subject: there's someone who makes an offset lug bolt? and I could use some for a possible upcoming project. Anybody have a line on those things?
Typicaly whats done is to get studs with a very large diameter and redrill the stud holes useing part of the old hole or turn the hub 45deg and redrill for the new pattern.
44
914Driver Dork
3/17/09 7:48 a.m.
What's an off set lug nut?
http://www.mr-lugnut.com/
Jensenman
Jensenman SuperDork
3/17/09 7:53 a.m.
It's a lug bolt which has an 'offset' to allow the 'wrong' bolt pattern wheel to be used. Someone posted a pic and a link a while back and I can't seem to find it anywhere. FIAT 4x98 could use a 4x100, RX7 4x110 could use a 4x108, etc. Mr. Lugnut didn't show it.
EDIT: Found it. it's called a 'wobble bolt'. Yeah, brilliant name. http://www.serpentautosport.com/wheel_accessories_lugs.htm
Keith
3/17/09 10:18 a.m.
Here's the clever result of trying to use 4x100 (I assume) wheels on a 4x114.3.
petegossett
petegossett GRM+ Memberand Dork
3/17/09 11:08 a.m.
Aren't those called "Unilug"?
Jensenman
Jensenman SuperDork
3/17/09 11:45 a.m.
The guys at the axle shop I have previously bitched about told me they could redrill my axles for 4x4 inches when I specifically stated I wanted 4x100mm and then 'you can just center the wheels and torque them down'. Yeah, right, bullE36 M3. I lost all respect for them over that one.
nickleone
nickleone New Reader
3/17/09 12:13 p.m.
4 on 4 inch Mustang early Falcon early Datsun early Corvair early Try theses. Nick
Jensenman
Jensenman SuperDork
3/17/09 3:07 p.m.
Um, sorry but all those were 4 x 4 1/2". Except maybe the Corvair. The MGB, TR6, 4 lug Toyotas and the early 4 lug Novas were also 4 x 4 1/2". The Pinto/Mustang II/4 lug Fox body were 4x 4 1/4 (4x108mm). The Jensen Healey, Midget/Sprite, Vega/Monza and Opel Kadett/GT were all 4x4". Spitfires and GT6's were 4 x 3 3/4" (with gigantical 3/8" studs).
oldopelguy
oldopelguy HalfDork
3/17/09 3:13 p.m.
Opels are 4x100mm, always have been. Don't know who keeps spreading that wrong information but no need for it here.
But the easiest and cheapest answer is going to be to just buy some trailer rims. Really, it is.
Jensenman
Jensenman SuperDork
3/17/09 4:12 p.m.
I stuck the Abomination rims on the GT I had and vice versa, never tightened them up since it was just for rollaround purposes. I just assumed the Opel was 4x4" since allegedly a lot of Opel stuff found its way under Vegas.
44Dwarf
44Dwarf Reader
3/18/09 3:43 p.m.
I thought Vega were 4 x 100mm just like the chevette as the spindle was originally a Isuzu part.
oldopelguy
oldopelguy HalfDork
3/18/09 3:52 p.m.
Vega and Isuzu don't share any parts to the best of my knowledge, H chassis and T chassis. Vega and Monza were all 'merican, best of what we had here in the good old USA.
Chevette, Opel, and Isuzu are all based on the same line, and are all 4x100.
Jensenman
Jensenman SuperDork
3/18/09 4:29 p.m.
The Vega is for sure a 4x4" bolt circle. The tranny in George Walton's Cosworth Vega is an Opel piece and the wheels for it were made by GKN in Britain. The front brake calipers are (IIRC) Kelsey-Hayes. Maybe the suspension was Vauxhall based; the Jensen Healey stuff is directly from a Vauxhall and is definitely 4x4".
44Dwarf
44Dwarf Reader
3/18/09 7:12 p.m.
Guess i should toss the on vega rim i have for my chevette based dwarf. I use a stock rim on the LF custom offset 8 inch wides on the rest.
ENEntZoeFWqW7RAJebduIdM0F7PUPxkOfsDid0hmKOribhCaZprtwokJEk93HuT2
