Maybe more CM than GRM, but thought I would get more hits here:
I'm trying to disassemble the water pump from my '66 Impala in hopes of rebuilding it and reinstalling it but I can't get the pulley mount off the shaft. You can see the bearing puller (which I cranked a bit tighter than I felt comfortable with) and some heat (not red hot, but hot enough to start smoking) with no luck.
So two questions remain:
1) is it supposed to come off?
2) does it NEED to come off? In other words, which way does the shaft push out of the housing? If I put it in a press and push on the impeller side, will it come out?
I tried an internet search, but the pumps I've found aren't quite the same (most of the ones I'm finding have a removable panel enclosing the impeller section, this one does not).
