killjoy7
killjoy7
1/25/10 9:00 p.m.
So I'm building a dedicated track rat out of my old RX-7 GSL-SE. I'm hoping some of you 1st gen rx-7 gurus/racers have some advice on alignment specs and ride height (the coilovers on the front are easy, might have to cut a coil to adjust height out back)
Suspensionwise, this is what it has:
Ground Control camber plates (front)
Ground Control coilovers (front)
tokico illumina 5 way adjustable struts all around
Eibach springs all around
Suspension Techniques front swaybar
removed rear swaybar.
I think this is fairly close to what the spec7, PRO7 spec suspensions were although my spring rates are not as high. not positive tho.
The car is basically for track days & HPDE so full race specs are great.
any help/tips appreciated.
thanks.
aussiesmg
aussiesmg SuperDork
1/25/10 9:02 p.m.
What tires are you using?
What tracks are you running?
Camber and caster are affected by both
killjoy7
killjoy7 New Reader
1/25/10 9:30 p.m.
In reply to aussiesmg:
tires are TOYO Proxes RA-1s on 15x7 rims.
Mostly northern california tracks: Sears Point (Infenion), Laguna Seca, Thunderhill.
aussiesmg
aussiesmg SuperDork
1/25/10 9:40 p.m.
Check with tire rack for detailed info on the tires, do they need a lot of camber or less, etc.
I am assuming these are all fast tracks with longer straights, am I correct?
PS: get a tire pyrometer
killjoy7
killjoy7 New Reader
1/25/10 10:25 p.m.
yes, all fairly fast tracks. Laguna Seca is probably the fastest.
Jensenman
Jensenman SuperDork
1/26/10 7:42 a.m.
Plus one on the tire pyrometer.
I ran 13" Kumho Victoracers on my '79 (mostly autocross) and I maxed out the caster and camber, IIRC it was something like 4.5 deg caster and 3.5 deg camber with ~1/8" toe out. 350 inch pound front, 200 inch pound rear springs, same Illuminas, stock front sway bar, disconnected the rear. Ran the suspension raked up approx 1/2" to the front. Don't use urethane rear bushings, learned that one the hard (expensive) way.
'Doug' at Ground Control was a big help with setup.
fastmiata
fastmiata Reader
1/26/10 8:13 a.m.
Most of the RX7 racers that I knew took the Watts link and threw it in the garbage can, then installed their own panhard rod for axle location. The Watts tends to bind and cause sudden oversteer. Take a look at the ISC website for ideas.
granny
granny New Reader
1/26/10 10:36 a.m.
In reply to fastmiata: I hear the hate for the early RX-7's watts linkage from many sources, but i just can't see it myself. My experience is that it's the rear 4 link that binds, not the watts link. As the body rolls, the 4 link's soft rubber bushings run out of compliance and suddenly become very stiff...snap oversteer. I just don't see how switching to a PB fixes that.
I've got an '85 RX-7 outside that's been converted to a torque arm...it has lower 2 links of the 4 link in the stock locations, but the upper 2 links have been removed. Still has the watts link, attached to the chassis in the stock locations. Without it's springs and shocks, it's rear axle can easily be articulated well beyond whats desired, to the point of looking more like a rock crawler. I just don't see any watts linkage bind that would likely cause sudden oversteer.
killjoy7
killjoy7 New Reader
1/26/10 1:03 p.m.
Thanks for all the input so far.
I don't actually have much money to invest in tri-links or custom rear end setups or anything right now.
Ultimately I'd probably be best to source a sorted out ex-racecar and stuff the 4port webber'd 13b I have in my ride but for now, just trying to get this puppy on track and handling as well as it can given the mods it currently has.
As far as ride height, cutting coils seems like the only way to lower the rear right?
Jensenman
Jensenman SuperDork
1/26/10 1:12 p.m.
Like so many things in the Grassroots life, performance doesn't have to be expensive. This mod works:
http://www.pbandjracing.com/rear_suspension.html
Best of all, it's dirt cheap.
If you already have Eibach rear springs, they should have one end that's 'coil bound'; it has three or four coils which touch, even when they aren't on the car. You can trim those as needed for rear ride height adjustment.
killjoy7
killjoy7 New Reader
1/26/10 1:41 p.m.
In reply to Jensenman:
great link. thx. Dirt cheap what I'm after.
aussiesmg
aussiesmg SuperDork
1/26/10 6:11 p.m.
Also before you eliminate original suspension pick up points be very careful about any class rules you may wish to compete in.
pFCWYGZoQD8W4JCoBGO8BuJAuIpf7hPNca2PvCiOFAiNGLcbbXJ32JiBADfcAWdU
