stan
stan GRM+ Memberand SuperDork
2/17/11 7:39 a.m.
Does the engine/tranny from a 914 fit into a 911? Good or bad idea?
Stan
Raze
Raze Dork
2/17/11 7:42 a.m.
Like all things on this board, it depends on what your definition of the word 'fit' is. Something like this is always a good idea.
tincetti
tincetti New Reader
2/17/11 7:43 a.m.
Google "912E" to see the factory version. A one year only model (1976) between the last 914's and the first 924's.
Otto Maddox
Otto Maddox HalfDork
2/17/11 7:58 a.m.
If you were going that route, you might as well put in a hopped up Bug engine.
2/17/11 8:27 a.m.
the type 4 engine in the 914 can be easily bored and stroked to 2.3 litres and be reliable. The 914 transmission is basically a 901 trans with a side shift (depending on the year) and a flipped ring gear.. so yes.. both parts will easily live under the rear of a 911.
and yes.. in 1976 when 914 production stopped.. Porsche had a few thousand type4 engines sitting around doing nothing so decided to resurrect the 912 name and threw them under decontented 911 bodies
T.J.
T.J. SuperDork
2/17/11 8:35 a.m.
Otto Maddox wrote: If you were going that route, you might as well put in a hopped up Bug engine.
I thought 914 engines were bug engines. There was the Beetle, and the Ghia, and the 914 right?
914Driver SuperDork
2/17/11 8:42 a.m.
No.
stan
2/17/11 8:46 a.m.
Raze wrote: Like all things on this board, it depends on what your definition of the word 'fit' is. Something like this is always a good idea.
True. A hammer and $$$$ and anything will work (as we've all seen many times here).
I was just looking at something a bit closer to plug-and-play and remembered the last 912s.
stan
2/17/11 8:48 a.m.
914Driver wrote: No.
...to T.J.?
Otto Maddox
2/17/11 9:05 a.m.
They share characteristics with VW van engines. Basically you get VW performance for Porsche prices.
2/17/11 9:09 a.m.
characteristics... but are the better engine. Just stay away from the 1.8
z31maniac
z31maniac SuperDork
2/17/11 9:59 a.m.
Please forgive my lack of knowledge about Porsche's, but are we talking about removing the flat 6 for a flat 4?
SilverFleet
SilverFleet HalfDork
2/17/11 10:09 a.m.
Otto Maddox wrote: If you were going that route, you might as well put in a hopped up WRX engine.
Fixed.
914Driver SuperDork
2/17/11 10:14 a.m.
...to T.J.?
To TJ. I didn't think they were Bug engines. I've never seen a fuel injected 2.0 Bug; but you know I've been wrong before.
Dan
stan
2/17/11 12:52 p.m.
z31maniac wrote: Please forgive my lack of knowledge about Porsche's, but are we talking about removing the flat 6 for a flat 4?
No.
Otto Maddox
2/17/11 1:00 p.m.
So what is the context here? Do you have a 914 engine and a 911 chassis just sitting around?
z31maniac
z31maniac SuperDork
2/17/11 1:37 p.m.
No.
Ok, maybe some more info for those who aren't Porsche fanatics?
I'm just confused since the few people I know with 914s ditched the motor for something else like a Subie or something......not to put in a 911.
Maroon92
Maroon92 SuperDork
2/17/11 3:25 p.m.
z31maniac wrote:
No.
Ok, maybe some more info for those who aren't Porsche fanatics? I'm just confused since the few people I know with 914s ditched the motor for something else like a Subie or something......not to put in a 911.
The 914 and 912E engine is a Type 4 case, the same as the later VW Bus 2.0 (though there are differences, not exactly the same).
The Beetle, Ghia, 356, 912 (standard), Thing, etc. Are Type 1 cases. Very different!
2/17/11 4:08 p.m.
the 411 and 412 also used the type 4 engine.. but as stated above.. they are NOT the same as the 912 and 914 engines
Otto Maddox
2/17/11 4:12 p.m.
Now that the technicals questions are answered, I am still really curious why someone would ponder such an endeavor.
amg_rx7
amg_rx7 HalfDork
2/17/11 4:22 p.m.
Otto Maddox wrote: Now that the technicals questions are answered, I am still really curious why someone would ponder such an endeavor.
I wonder that also. Most 914 owners swap a 911 trans into the 914 as an upgrade
2/17/11 4:32 p.m.
I must have been the only person in the world who liked the strange pattern the 901 trans has..
I happen to like first down and the left.. with 2nd up with 1st normally is.. but then I used to drive a truck then and that transmission was set up the same way
Otto Maddox
2/17/11 4:38 p.m.
In reply to mad_machine:
That's the other problem. A 914 might be the only sporting car on earth with a crappier transmission than a 911.
z31maniac
z31maniac SuperDork
2/17/11 5:35 p.m.
That was kind of my question........
ww
ww SuperDork
2/17/11 5:53 p.m.
I would be more inclined to put a flat 6 911 motor in the 914. Or a WRX STi motor in the 914... or a 911 for that matter! ;)
mBlDuUsGVg2LlJLx8FDamVAjepzFCEYXNrTwBdI6C8xX0bKOX8QEaxMzjBGbdh59
