BTerj
BTerj New Reader
10/18/15 12:10 p.m.
Is there a likely place for a slow oil leak on the front of the 95 miata motor?
Thanks Brian
kazoospec
kazoospec Dork
10/18/15 12:40 p.m.
Valve cover gasket? My 94 was weeping just a little bit from the driver's front corner when I first got it. It was running down the block and showing up on the front side.
thedanimal
thedanimal New Reader
10/18/15 2:06 p.m.
Valve cover is certainly the quickest and cheapest spot to start, mine leaked on the back where they all seem to. Then formed a small leak on the side about a year later. Also I had small oil leak at the front around the crank seal that was sorted when my timing belt was done.
cJvb41nAfHklhpemkOnMFqFBpZuHtspNQsOYiwXUugkSPzOmzF5slduiQKP00VL7
