Grizz
Grizz UltraDork
3/21/17 3:03 p.m.
So I was replacing some sensors on my cousins Colorado (06, 2.8). Cam and crank position sensors were easy peasy.
My question is, how the hell do I get the 02 sensor off the manifold with that stupid effing heat shield in the way and why the effing hell did gm design it so it's impossible to get a wrench on it?
Streetwiseguy UltimaDork
3/21/17 3:24 p.m.
Same reason everybody else did. Now quit whining and get busy stripping the hex, then tearing out the threads, then replacing the manifold, then fixing the manifold studs, then...
Grizz
Grizz UltraDork
3/21/17 3:31 p.m.
I don't get paid enough to do all that.
Dr. Hess
Dr. Hess MegaDork
3/21/17 4:01 p.m.
The easy way is the gas cap trick.
Grizz
Grizz UltraDork
3/21/17 4:09 p.m.
What's that?
Stefan
3/21/17 4:12 p.m.
Remove gas cap, roll newer truck under cap, replace gas cap.
Dr. Hess
Dr. Hess MegaDork
3/21/17 4:14 p.m.
Stefan wrote: Remove gas cap, roll newer Toyota truck under cap, replace gas cap.
FTFY. And sometimes you need a new gas cap too.
Stefan
3/21/17 4:25 p.m.
In reply to Dr. Hess:
Copy that.
BrokenYugo
BrokenYugo MegaDork
3/21/17 4:33 p.m.
Read the manual?
NEALSMO
NEALSMO UltraDork
3/21/17 4:45 p.m.
You need one of these probably-
I borrow one from a fellow tech every once in a while for MINIs with it set deep in a heat shield.
APEowner
APEowner GRM+ Memberand Reader
3/21/17 5:25 p.m.
NEALSMO wrote: You need one of these probably- I borrow one from a fellow tech every once in a while for MINIs with it set deep in a heat shield.
For installation you may need that. For removal, cut the wire and use whatever you need to in order to get on it. You may also need heat.
nHctMqtEEOumZuuu9d6gpzAc4XyINEL6pz18GrwDoGlATEzkSRNYP8IYeExvtWSc
