Matthew Kennedy said:Yep, and inline engines are terrible for aviation use because they're large and heavy for a relatively small amount of displacement. A V12 is far less than double the size of an inline six, but has double the cylinders and displacement.
Aero piston engines generally try to minimize the amount of crankcase and crankshaft required for the most displacement, because those are the heavy parts. Long inline and V engines are also poor choices if air cooled, so those are generally large, high performance water cooled engines.
One of The reasons the V12 is most commonly used for airplanes is because it produces a narrow frontal area for its power. When Rolls Royce developed the V12 they put a man in a chair and used the space from his feet to his shoulders as the maximum area they could build in.
Unlike a six cylinder which needs an intake on one side and exhaust on the other side limiting total displacement. A V12 could be fed air and fuel in the V. From either the supercharger in front or rear of the engine.
How compact is a V12? Well the Jaguar V12 which can be bored and stroked to 10 &1/2 liters or about 700 cu inches.
Is about 20 inches wide. Yes that includes the exhaust manifolds. That’s just one of the advantages of a 60 degree V over a more common 90 degree V
To make a 700 cu in V8 is at least a foot wider to the exhaust manifolds and anything with the valves splayed to make power might be another foot over that! Times the total height of the motor. Let’s for the sake of argument assume 3 feet.
So 6 sq feet more frontal area is a massive amount of drag if you’re trying to go 400 mph.
In addition the more narrow V of 60 degree’s provides added stiffness over the 90 degree V
All radial engines use massively more frontal area than water cooled engines. While an air cooled engine is simpler and shorter than a water cooled engine it does have it’s own issues. Bulk being chief among issues, Also oil consumption 50 gallon oiling systems being the norm.
The 4360 corncob is a 4 row 36 cylinder radial engine that is more than twice as heavy as the Complete Rolls Royce Griffin which made 2450 horsepower compared to the Corncob at 3700 hp. But two Griffons would make 4900 horsepower. One other point The Roll Royce engine was ready before the start of WW2 while the 4360 corn cob wasn’t until nearly the very end of WW2
