foxtrapper
foxtrapper UltimaDork
9/1/16 12:44 p.m.
Build Thread
Teaser Picture
NOHOME
NOHOME PowerDork
9/1/16 1:07 p.m.
Seems to be a trend of Jet engines in small cars.
http://retrorides.proboards.com/thread/171980/spridjet-big-bang-edition?page=14
akylekoz
akylekoz Reader
9/1/16 2:55 p.m.
So how do you go from 53,000 rpm to a standard rear gear. Guess it just depends how well the coupling in the turbine works. May be a dog out of the hole, but whatch out once its running. Maybe it will be a better lake car than a track car.
GSmith
GSmith HalfDork
9/1/16 3:29 p.m.
slow start, but imagine the top end!
That Spit may need wings.
dean1484
9/1/16 5:16 p.m.
Gear reduction translates to torque and at 50,000 plus rpm you would be reducing it by a lot and upping the torque a bunch I would think. Does anyone know how fast a Jet engine spools up?
XLR99
XLR99 GRM+ Memberand Dork
9/1/16 7:25 p.m.
Looks like an Allison 250 like you see in Bell 206 helos and Bonanzas converted to turboprop power.
So is the gearbox output just connected to a regular car transmission? These things usually operate in a pretty small RPM range. I can't remember if these are a split shaft like a PT6, but I'm sure Appleseed and the other pilots will know.
ssswitch
ssswitch Dork
9/1/16 7:41 p.m.
The thread says it's just direct drive, but I've not gotten far into it.
Do you even get throttle control with something like this?
edit: Looks like you do, but with immense lag.
sJwvzcMWuyZWrDYzVugFEq0UpuG2VEsOyPUZ08TX6qJygbSELugTAQKdi4IbDGZM
