stroker
stroker UberDork
12/27/21 8:14 a.m.
Let's see Bad Obsession do this...
Yeah, I know it would have been easier to just buy an engine, but it's still fascinating.
Trent
Trent PowerDork
12/27/21 10:01 a.m.
Check out Allen Milyard
This gentleman is the master of adding cylinders to motorcycle engines.
californiamilleghia
californiamilleghia UltraDork
12/27/21 12:40 p.m.
just watched Allen put the lower end together of his 3 , now 4 cylinder Kawi ,
He makes it look so easy !
Run_Away
Run_Away GRM+ Memberand Dork
12/27/21 3:30 p.m.
That's amazing. I can't imagine the thought going into figuring out it would be best to rotate the cylinder location, the machining inside the cases for clearance, the split plates he's using to support the main bearings. The tolerance stack of gaskets between all the cases. I'd be so worried about would the transmission be able to handle the 4x output? Would the single timing chain be up to the task? Stress full.
How is he going to run spark plugs, or wires?
stroker
stroker UberDork
12/28/21 7:47 a.m.
In reply to Run_Away :
Yeah, I was wondering about that, since the heads cover access to the plugs...
DrBoost
DrBoost MegaDork
12/28/21 9:01 a.m.
Welding in sandals an no socks, for the win!
e18EEp9uMmFf4tXdA0kd9lPe1DYkY4QaLNPpwyncl3ZGZHjmkCB4RUXmzVdADUBz
