midknight
midknight New Reader
7/18/08 2:16 a.m.
I'd ask this on one of the Honda boards, but you, my friends, are so much more tolerant of my ignorance. :-)Timing belt went on 95 Accord 2.2 lx non-vtec. Interference engine.of course. I can get a good vtec head and ecu for $100. Can this work on my bottom end, and if so, what else would I need? Thanks,
Mid
oldschoolimport
oldschoolimport New Reader
7/18/08 2:38 a.m.
I'm not positive, but there may be some wires for vtec that will need to be added, plus the vtec solenoid itself will need to be sourced if it doesn't come with the head. they are both f22 bottom ends, so it should mount no problem. when you do ls/vtec on a b-series, you have to add a pressurized oil source access, since the non-vtec blocks don't have a source from the factory. you may want to poke around at honda-acura.net to check the subject more indepth. its been a while since I've messed with accords.
EDIT1.
I did some research.
here is one thread its not a how to, its more of a "why goto the trouble for 7hp". sorry.
full write up in the 4th post on this one.
EDIT2. you have to be registered (I'm anal enough to check for ya) so here is the write up from the second link.
In the quest for more power for my Accord I came to the conclusion that a turbo was the only thing that was going to make me happy. I toyed with the idea of the Eclipse manifold rig job or having something made. After seeing impressive dyno results of the SOHC VTEC engines with boost I decided that I must have this feature. I didn't really want to pull out my bottom end though. Knowing that the F series is MOSTLY identical to each other (save the F23's which have different sleeves etc) I figured I could just plop a F22B1 head on the car.
Another factor in this decision is the abundance of off the shelf turbo kits for the 94+ Accords. Having a manifold fabricated is a cool idea, but I just rather have an off the shelf kit. What’s really great about doing this is the price. Most swap-shops are trying to GIVE away F series engines...
Well what better way to start off this how-to but with a parts list. My parts list assumes you have a 4th gen Accord. If you're a 5th gen owner you wont need the intake manifold, so just use your head on the rest. I'll also list the places and prices I paid:
1.) F22B1 head; (eBay - $100.00) You'll need a valve cover too... which I got off a forum member for $30.00. 2.) F22B1 or B2 Intake manifold & throttle body THIS INCLUDES THE THERMOSTAT HOUSING!!!; (Forum Member - $50.00) 3.) 94+ water intake hard pipe (water pump to the thermostat housing); (Forum Member - $5.00) 4.) Timing belt (the 94+ EX are specific due to the head being slightly taller!); (AutoZone - $45.00) 4.) P0A ECU; (Forum Member - $35.00) 6.) All associated seals & gaskets (Depends, but figure $100-120 if you're being smart and replacing old seals); 7.) Exhaust manifold that'll fit a 94+; (Forum Member - Free) 8.) 94+ Throttle Cable; (AutoZone - $22.00) 9.) Proper spark plug wires. (AutoZone - $45.00)
Tools what will make this job a lot easier or you flat out need: 1.) Brass scraper (don’t ass up your aluminum block & head scraping on it... be smart and use a brass scraper). 2.) Crank pulley tool (I don't know how I ever survived without this) 3.) Of course you'll need varying levels of torque wrenches, don't even attempt this without proper torque wrenches.
Abbreviations: MAP = Manifold Absolute Pressure sensor; IM = Intake Manifold TB = Throttle body VTS = VTEC spool solenoid VTP = VTEC pressure sensor IAC = Intake Air Control (called EACV on older Hondas... what I'm used to) EM = Exhaust manifold IAB = Intake Air Bypass solenoid
Taking it apart: I'm not going to dwell on this too much. If you're going to attempt this you damn well better have a service manual! Basically keep taking things off until you have a bare head in front of you. My engine was leaking oil pretty bad from the oil pan and front main seal. Since you'll be up there to replace the timing belt anyway why not change all those too? I also took this time to really degrease and clean my engine, transmission and compartment. So, in review here’s everything I replaced/freshened up:
1.) I removed the oil pump housing and made sure the oil pump rotors were within service limits. 2.) Replaced all o-rings, front main seal, and balance shaft seals. 3.) Thoroughly cleaned and scraped the oil pan and oil pan mating surfaces & replaced the gasket.
Assuming you're a 4th gen owner, go ahead and pull out the water intake hardpipe on the back of the block use it to launch a bottle rocket or something. Install the 94+ pipe and call it good.
Prepping the head/block & others: In today’s world of multiple-layer metal head gaskets, head/block trueness & cleanliness are of utmost importance ...if you want a head gasket that wont pop on you in 20 miles. Throughly scrape the head and block with a brass scraper. Caution must still be taken even with a brass scraper to not nick or gouge the delicate aluminum surfaces. Hopefully you took the time to clean the engine compartment, block & head before reassembly as well! Also take care that pieces of old gasket & muck dont fall into the oil gallery drains or water jackets by using rags.
On the bench go ahead and bolt the intake manifold to the head if it isn’t already. Its just way easier on the bench.
Finally for us 4th gen owners... there is a bit of business we need to do on our heads. In 1994 Honda redesigned the F series a bit on the front middle head bolt region. They added a little ledge that covers/seals a water casting hole from when the head is molded. They use those to sand cast the aluminum. Why is that a problem you ask, well as I found out (the hardway I might add) without that ledge it LEAKS water (pours is more accurate). Therefore it MUST BE SEALED. I used a crapload of JBweld (I love this stuff!). Feel free to seal it however you please, but do it or enjoy no cooling system. Once again this only applies to 4th gen owners. I assure you this hole is only a sand casting drain and on the 5th gens is totally sealed by the head gasket against the ledge.
Prepping the wiring harness: For the most part this will remain unchanged, but a couple things do need to be added and one item moved ...if you have a 4th gen.. You'll be adding 3 wires: 1.) VTEC solenoid trigger 2.) VTEC pressure sender 3.) ground wire for VTEC pressure sender
Add these 3 wires to the thermostat housing/EGR area of the wiring harness and we'll discuss ECU pin outs later in the how-to.
Now the item that needs to be moved is the IAC / EACV (whatever you want to call it) plug & wires [2]. You'll find this plug on the plastic injector wiring bar. Open the plastic injector wiring bar and pull out as much of it as you can from there. Cut the connector off and untape the harness enough to get the 2 wires heading toward the TPS sensor connector. You're going to have to solder about 12-14" of wire to make it reach. I just loomed the TPS & IAC together and made a Y so they could reach their respective receptacles. As I said earlier this is the OPTIMAL time to totally retape & loom the wiring harness if yours looks bad like mine did. Once again only 4th gen owners need to move the IAC connector.
Finally you're going to have to make a choice on the MAP sensor. You can either A.) find a connector in the junkyard that will fit the MAP on the TB or B.) reuse your MAP sensor and just run a long piece of vacuum hose over to the drivers side of the IM. I chose option B for right now. If you're a 5th gen owner this doesn’t apply to you.
Prepping the ECU: This was really easy for me. While I do have brand new pushpins (hey I used to do a lot of motor swaps) I reused what WAS my automatic rear motor mount solenoid (this is also the IAB on 90-93 EX models or anything else that was equipped with IAB) and power steering (I removed mine) pressure sender pins. If you didn't already know Honda was really nice and you can snap open the connectors on the ECU side and move pins around. No matter WHAT way you decide to do this you need to add two pins: D6 (VTP) and A4 (VTS) [See wiring harness pin out chart I've included]. The VTP ground... well just ground it anywhere. It doesn’t matter, its just a simple on/off pressure switch.
NOW for 4th gen owners we get to do a little more work/make a choice. In 1994 Honda decided to swap pins A11 and A6 (EGR & 02 Heater respectively). To my knowledge this is the only OBDI car Honda did this on. ANYWAY your choices are as the following: 1.) Swap pins A11 & A6 while you have connector "A" apart adding VTP. 2.) Open up the P0A ECU and cut A11 & A6 and reverse them via internal modification (IE: wires crossing them... see attached picture).
I chose option 2 because I do a lot of ECU testing and changing my harnesses pin out for one lousy ECU isnt in the cards. Anyway thats it for wiring. Go ahead and put the wiring harness back on the car as its much easier to do with the head off.
Reassembly of head to block: Once again we wont dwell here too much, its pretty self explanatory with a manual. Just remember to make sure your head bolt holes are clean and the head bolts are clean & oiled with fresh engine oil. Three or 4 stage them down to 78 ft. lbs using the proper tightening sequence. Make sure the bottom end & head were set to TDC properly!!! You don’t want to bang pistons on valves rotating stuff around! I guess the only real advice I have here is make sure that your mating surfaces on the block & head are CLEAN and DIRT FREE.
Intake manifold & fuel lines: If you have a 94+ just ignore what I'm about to write about fuel feed & return lines. 90-93 the fuel feed is on the passenger side of the fuel rail, 94+ its on the drivers side. The 94+ uses the same size fuel feed banjo as a 90-93. So all I did was cut & extend my fuel hose (MAKE SURE YOU USE REAL FUEL HOSE) using clamps and bits of stainless tube. Ya, this is a big rig... but my ultimate goal is to get some braided lines made for the car anyway. The fuel return hard-line is a little smaller than the 4th gen one, but with clamps it snugs right up too.
Some other little things will need to be lengthened (read: replace the hose) here and there like the brake booster vacuum hose. There’s just a couple little things like this and will all be very obvious as you're putting the car back together. Also make sure you cap off any unused vacuum lines on the drivers side of the IM... you don't want a goofy idle!
Timing belt and related: 94+ EX models use a slightly longer timing belt due to the cam being higher (the head is quite a bit larger physically). So don't even waste time, just go choke up the money for a new belt. This is also an optimal time to replace the water pump & timing belt tensioner if its been awhile! Slip on the new timing belt and tension it properly according to the published Honda methods.
I chose NOT to replace the balancer shaft belt on my engine. People think its risky and maybe it is, but I wanted to see if it would give me a couple ponies... and I think it has. I also used this opportunity to make home-made solid motor mounts for my car (since to properly do the timing belt you pretty much need to remove the front, rear and side motor mounts anyway). Go ahead and check your valve clearances and then button up the cover! As always I recommend spinning the crank around a few times by hand to ensure it stays in time and that you have no mechanical interference.
Exhaust and related: Pretty self explanatory. I ended up using a 94+ LX header for now because the EX has the O2 bung on the down pipe. With everything else going on with the car I didn’t want to add lengthening my O2 wires to the list of E36 M3 that could go wrong. Use whatever header you like.. DX/LX ... EX.. or an aftermarket obviously too. The down pipe ended up being like 6" shorter than my old Pacesetter 4-2-1 I had on the car, so I used some flex pipe for now. I'd have something properly welded into place, but why bother when turbo is my goal in the immediate future.
Throttle Cable: The 94+ throttle cables are a tad longer. While you can (and I DID) rig it temporarily, I recommend doing it right. Replacing the cable is trivial and in the long run just plain safe.
Wrapping up: Reconnect all of the wiring to the head etc. Your original distributor will fit, so just put it back on! Fill the sucker with water and oil and look around for obvious leaks. Before putting spark plugs in the head I'd crank it over a few times with the starter to put some oil up into the head ... make life a little easier on the cam bearing and all that jazz. Also be SURE that your fuel lines aren’t leaking. Furthermore I'd have a fire suppressor and/or hose around just in case!
Put in your spark plugs, wire them up... and she'll fire up with any luck! Thankfully when I turned the key on mine I got no CEL's and good oil pressure. Mine popped in about 2 seconds of cranking, I was truly impressed. Obviously let it run for a bit and check for oil & water leaks. While you're waiting for that to happen, now’s a good time to check your ignition timing... its GOING to be off since the distributor was off the car! If alls well, hop in and go for a ride! Congratulations.
oldschoolimport
7/18/08 3:08 a.m.
this may be a better site for ya. I just found it. http://www.accordinglydone.com/forum/forumdisplay.php?f=31
integraguy
integraguy New Reader
7/18/08 11:43 a.m.
If this were my car, AND I had a buttload of cash, I'd do an H23 swap on this car....assuming it had a manual tranny. If you use the H23 out of a Prelude you are getting 190-200 horsepower....BEFORE further mods.
Strange, but I've never heard of/seen anywhere, the LS/VTEC swap done on an Accord, just on cars with the "B" series engines. Sounds interesting...sort of.
midknight
7/18/08 3:15 p.m.
Wow!! Thanks Oldschoolimport!! Lots of reading and learning. I love this board!! Integraguy, cash and I have a strained relationship. It is repulsed by my wallet and seeks to escape quickly and often. Car is a manual and I would love an H23, but not likely in the next year at least. Just need to get this puppy back on the road.
oldschoolimport
7/18/08 3:30 p.m.
integraguy wrote: Strange, but I've never heard of/seen anywhere, the LS/VTEC swap done on an Accord, just on cars with the "B" series engines. Sounds interesting...sort of.
I was just using the build of an ls/vtec as an example.sorry to be confusing.
midknight wrote: Wow!! Thanks Oldschoolimport!! Lots of reading and learning. I love this board!!
no prob man, just glad to help.
L4UJXKb18N2QTtPwhGZisN25MMEs7VFoBmUpNSVlawYnOrDtwDNwrq6NMgTEbMmB
