RealMiniParker
RealMiniParker UberDork
1/14/18 6:25 p.m.
Step-daughter's '09 Nissan Altima broke a front spring, at ~95k. Should I (she, really) spend twice as much, and replace it with a loaded strut ass'y, or go through the exercise of wrestling with a spring compressor and just change the spring? Should I do both sides?
Toebra
Toebra HalfDork
1/14/18 6:48 p.m.
Seems like you ought to do both sides, but if it ain't broke, don't fix it.  How about getting a pair of strut assemblies from a wrecking yard, then you don't have to mess with spring compressors.   Alternatively you could tale the assembly with a broken spring off the car and have a shop do the spring compressor gymnastics.
RealMiniParker
1/14/18 7:00 p.m.
In reply to Toebra :
Car-part lists used struts for as much as new ones from RA. Wrecking yard? Nah, I'm berking around in the cold with rustbelt cars.
What does a shop typically charge to do springs? A pair of springs is ~$80, loaded struts are about that much, each.
Kramer
Kramer Dork
1/14/18 7:01 p.m.
Loaded struts aren't that expensive, and easy to replace.  After 95k, you need new struts anyway.
Run_Away
Run_Away GRM+ Memberand HalfDork
1/14/18 7:06 p.m.
Pretty common problem, I've changed lots. FWIW, we just change the one spring.
RealMiniParker
1/14/18 7:06 p.m.
In reply to Kramer :
Thanks, that's the confirmation I was looking for. wink
ProDarwin
ProDarwin PowerDork
1/14/18 8:26 p.m.
And probably of better quality.
iM0jcAzRDSJXCKMXKHmPrWcv0di9HDDZlafFwkcg5ewxdai4ISClC3jlVOlc7Z0c
