vdubinsd
vdubinsd New Reader
10/1/12 10:15 a.m.
After doing a bunch (not that much, really) on a 85 Corolla that I bought for the local 3/8 mi dirt oval, the engine let go after 4 laps...but it was long enough for me to realize that a 1.6 carb worn out motor was never going to be competitive. So now I see a pile of parts versus a racecar. Time to find a new car.....
The rules are 1. 4 cylinder only 2. SOHC only. 3. 2.6 liter max.
I want to stick with front wheel drive, since I have somewhat of an idea on how to drive it (it is different on the dirt, that is for sure). The class seems to be dominated by neons.....but that seems to make them dissappear off craigslist quickly.
My ideas so far are Altima, Camry, Accord-all tough to find in manual.....
I would run a A2 Golf sooo fast, but no 16v allowed :(
N Sperlo
N Sperlo PowerDork
10/1/12 10:24 a.m.
Cavalier. 2.2 L and should hold up with the neons.
Check out mine in my garage.
ClemSparks
ClemSparks PowerDork
10/1/12 10:31 a.m.
And they are super-low rolling resistance when they are in the freaking AIR.
Sperlo...hook us up with a photo!
N Sperlo
N Sperlo PowerDork
10/1/12 10:33 a.m.
ClemSparks
10/1/12 10:34 a.m.
Yep...that's what I'm talking about!
"I can't get the power down!"
81cpcamaro
81cpcamaro Reader
10/1/12 10:35 a.m.
I would agree with the Cavalier as well. Plenty of GM cars used the 2.2L engine & trans so replacements will be easy and cheap to find.
N Sperlo
N Sperlo PowerDork
10/1/12 10:36 a.m.
I look forward to flying again.
GameboyRMH GRM+ Memberand PowerDork
10/1/12 10:37 a.m.
+1 for Cavalier, I don't think you're going to do better within those rules.
failboat
failboat Dork
10/1/12 10:39 a.m.
while everyone else is shopping for cavaliers, you could be shopping for a SUNFIRE!
I would think the weight of the larger cars would not help for racing.
N Sperlo
N Sperlo PowerDork
10/1/12 10:39 a.m.
81cpcamaro wrote: I would agree with the Cavalier as well. Plenty of GM cars used the 2.2L engine & trans so replacements will be easy and cheap to find.
Tires and wheels as well. Cheap and plentiful.
Actually, I'll sell you my escort zx2 dirt cheap. That would be my second suggestion. I damage the front end the other day and its prefect for dirt track. I don't know if the stage 2 clutch or exhaust manifold or Eibach springs or upper strut bar would be legal.
Aargh. Dual cams. Never mind...
poopshovel
poopshovel UltimaDork
10/1/12 11:22 a.m.
No turbo dodge love? Wayne used to kill Mustangs and Pintos in Pony Class in a 1g crx. .040 over with integra pistons and a nasty cam will yield good results. Seems like Neon is a good answer too.
vdubinsd
vdubinsd New Reader
10/1/12 11:35 a.m.
Since I work at a GM dealer, looks like I see my next craigslist search....should be "findable" in a manual....
Looking at Sperlo's garage now
I was thinking the weight of the bigger cars wouldnt be that big of a deal, since all Japanese cars of that era are super thin metal...the coroola I have is held together by the cage
BoneYard_Racing
BoneYard_Racing Reader
10/1/12 11:49 a.m.
You said no 16v? Is that the rule or is it SOHC only? SOHC neons are 16v. Allow me to suggest an Lbody Chrysler (Omni, Horizon, Charger, Turismo) get a 2.5 block, TBI 2.2 (cast "782" on water neck) head, TBI roller cam, and, decent header and carb should be 160hp or so and run on pump gas 12:1 compression
demonspeed
demonspeed Reader
10/1/12 11:49 a.m.
I work on a pit crew for a 4 cylinder fwd asphalt car, which is a sunfire. The sunfire is not a bad choice but we've found that a saturn would have been better, as they seem to be outrunning us lately. I'm not sure what model they are, but they are 2-door, overhead cam, and have independent rear suspension. They're a little down on power but they handle better, because they're supposedly way lighter.
Travis_K
Travis_K SuperDork
10/1/12 3:11 p.m.
I havent driven a dirt track car, but I drove an automatic cavalier and it was slower than a 4 speed 240d. Why not an 8v vw? An mk3 jetta would be cheap and that seems like it would be decent.
vdubinsd
vdubinsd New Reader
10/1/12 3:15 p.m.
16v is ok, 2 cams are not
thought about Saturns, but I thought (presumed) they were heavy
good ideas, I have yet to see a Cavalier or Saturn on the track
ST_ZX2
ST_ZX2 HalfDork
10/1/12 3:27 p.m.
Focus LX Sedan or 98+ Escort 4-door...both had 2.0 8V SPI engine.
bearmtnmartin
bearmtnmartin GRM+ Memberand Reader
10/1/12 3:29 p.m.
Honda Honda Honda. Our 4 cyl class is developed to the point that some of the other tracks will not let us race there, and the winning front wheel drives are all Honda. Neons, Cavaliers, Saturns Mustangs have all been tried and tossed. CRX, Prelude, Integra, and Civic are all competetive out of the box. They are fast, they don't overheat, and they don't have oiling problems, especially if you shim the pump. Also the junkyards are full of them, which is huge all by itself.
bearmtnmartin
10/1/12 3:30 p.m.
Focus is slow. Some of the cars that look like winners on paper just aren't, especially in a class where you cannot really modify anything.
N Sperlo
N Sperlo PowerDork
10/1/12 4:03 p.m.
ClemSparks wrote: Yep...that's what I'm talking about! "I can't get the power down!"
"I also can't get the berkeleying dirt out of my mouth!"
moparman76_69
moparman76_69 Reader
10/1/12 4:09 p.m.
I was going to suggest neon. The cheap ones go fast around here also, several local classes do the 4 cyl classes and they seem to be quick. If you go neon get a 4-door they are lighter than the two doors.
procainestart
procainestart Dork
10/1/12 4:27 p.m.
There's a guy in Kansas who's been quite successful circle tracking classic Saab 900s (asphalt, though). Buy a 91 or newer non-turbo, which came with a 2.1 L 16V, and put an 8V head on it from an earlier car. Or put a 2.1 bottom end in an 8V NA car.
The benefits are: cheap; double wishbone front end with easy camber; easy weight jacker install; easy gearing changes without pulling the transmission (it is chain driven and the primary chain gears are accessible, with various ratios over the years, to mix and match); and a durable body. Rear axle can be modified for camber adjustment, or bent.
vdubinsd
vdubinsd New Reader
10/1/12 4:39 p.m.
Saab-interesting, but few and far between in my area-and pick a part parts are a necessity.
Focus-would have to be wrecked prior to me wrecking it on the track; I want to be comfortable laughing if I kill it, and a Focus would likely hurt the pocketbook too much to do so.
Escort-hmmmm, have to scope the local yards to see what parts availability is like...and would have to be notably faster than the Cavafire, since I get GM parts cheap, and the boss might help with expenses if I plaster the dealer name on it....
Honda-Prelude, Interga are dohc-and dohc is no go-can a D15 be fast? I didnt think it could, but worth a google
VW-Actually have a 80 Rabbit shell, and thought of doing the ABA block with CIS head, but there is a mk2 Golf 1.8 that is consistently in the bottom of the pack-the neons tear it up.....
And rules state engine has to be 100% stock-air filter and exhaust manifold back are open, other than that no mods allowed (unless you donate a ton of money to the track, like the class winner) and NO forced induction-factory or not
donalson
donalson PowerDork
10/1/12 6:27 p.m.
I know saturns where top finishers at the dirt track where I was in FL...
also might check the classifieds on the track web page... from time to time you could find a ready to race car with a tow dolly for $1000 or so... not a bad way to get in for starters...
White_and_Nerdy
White_and_Nerdy HalfDork
10/1/12 7:05 p.m.
Saturn S series cars weigh in around 2400lbs. Since you're limited to SOHC, look for a "1" model (SC1, SL1, SW1), or the basic SL. Go 95+ for a whopping 100hp. Where this engine has it is the torque, which is what you really need for pulling out of the corners. A 2.2 Cavalier will certainly have more of that, but also a lot more weight.
Most importantly, those polymer dent resistant body panels will come in very handy at the roundy-round.
f2Q5JZNTm39Ff5i7uLQEAvJ3W4s2eXWTBTmah2UQ46ZYs61oaNcGuiUfvAsL9v5c
