jimbbski
jimbbski Dork
11/15/18 1:07 p.m.
If you want to make that machine more useful I'd look around for a compound sliding table. Get a quality one and bolt it to the table you have then you can either use hold downs or a simple drill press vise bolted to the table to hold your work. Want to drill a series of holes in line, just crank the handle a few turns.
Jumper K Balls
Jumper K Balls PowerDork
11/15/18 1:09 p.m.
I honestly feel like that piece of equipment wasn't intended to have an electric motor and originally came from a belt driven shop
That is an OLD machine there.
edit: and an awesome one.
AWSX1686
AWSX1686 GRM+ Memberand SuperDork
11/15/18 2:06 p.m.
In reply to Jumper K Balls :
It’s certainly possible!
AWSX1686
11/15/18 2:06 p.m.
In reply to jimbbski :
I’ll have to keep an eye out for one!
Toyman01
11/15/18 2:19 p.m.
You might try Surplus Center for a motor and speed control. I converted my 40s era lathe to variable speed using a 2.5hp treadmill motor and a Surplus Center speed control.
These are the parts I used.
2.5hp Motor, $50
DC Speed Control, $90.
Pete Gossett
11/15/18 2:55 p.m.
SVreX said:
In reply to Pete Gossett :
I’m not sure why railroads would need square holes.
Maintenance shop for wooden railcar repair.
SVreX
SVreX MegaDork
11/15/18 3:19 p.m.
Yes, you are probably right.
stuart in mn
stuart in mn UltimaDork
11/15/18 5:18 p.m.
Or maybe rail car construction as well.  A lot or railroads built their own rolling stock.
AWSX1686
11/19/18 8:35 a.m.
Well, I got it home and into my garage! Should have taken a video of the process as it was quite the process. It's a good 7'3" tall, while my garage doors and I-Beam are 7' tall, so we had to put it on it's side, gently tipped it over via winch, then basically dragged it in via winch, then somehow the 4 of use managed to lift it back to an upright position. This thing is heavy! We thought about going to the scrap yard to get weighed before unloading it just to see how heavy it was, but didn't mess with it. I'm thinking it's like 1500 pounds.
I will start a build thread soon, as I go through and clean it up and everything. I have a few other things I need to finish up first. Might even make some YouTube videos of the restomod process.
AWSX1686
11/19/18 8:39 a.m.
Oh, and I did test out functionality! And got a video of it!
Yes, yes, I know 220v is dangerous...
Don't try this at home kids!
AWSX1686
11/26/18 10:40 a.m.
So this thing has some history:
Likely owned by the CRI&P Railroad at some point. (Asset tag: CRI&P Tool No 265)
Likely owned by "THE FADER MACHINERY CO Inc." (Plate mounted on the side.)
According to the farmer I picked it up from, he bought it from a well known Organ company in Hagerstown, MD.
AWSX1686
11/26/18 10:44 a.m.
Now, just what IS this thing exactly?
Well, now that I removed the electrical box that was mounted on the side, we can see pretty clearly!
WYSONG & MILES CO: Model 283B
Vertical Boring Machine
It must have been converted at some point  to use the pulley/electric motor that is does now, because a google image search brings up what they were like originally.
dherr
dherr GRM+ Memberand HalfDork
11/26/18 11:02 a.m.
That would be the M.P. Moller Pipe Organ Company, I remember seeing their name on a large old building in Hagerstown.
That is one heck of a drill press!
AWSX1686
11/26/18 12:11 p.m.
In reply to dherr :
Cool!
Yes, I can't wait to have it cleaned up and ready for general use. I couldn't pass it up!
AWSX1686
11/26/18 12:15 p.m.
Does anyone know if there is a real difference between a drill press and a vertical boring machine? Seems like two ways of saying the same thing.
dherr
11/26/18 12:28 p.m.
In reply to AWSX1686 :
It is pretty cool, but that is one tool, I won't ask you if I can borrow it :-)
dculberson
dculberson UltimaDork
11/26/18 12:54 p.m.
Was that live 220v on bare wires you were handling? WTF? Even if you're committed to "plugging it in" that way, why not turn the supply off then back on once connected? I was sweating once I realized those lines were live.
So based on the pictures of more original machines, is the large cylinder the motor housing? Maybe they took out the motor and replaced it with a shaft when the original motor went bad or in the process of converting it to single phase?
AWSX1686
11/26/18 12:58 p.m.
You're welcome to come use it once it's ready, but yeah, not gonna drop that off to you in the miata!
AWSX1686
11/26/18 1:00 p.m.
Yeah, the 220v shenanigans was not the smartest... But no one was hurt.
Yes, originally the large cylinder contained a 3-phase motor. Not sure exactly how the shaft and pulley were added for the single phase electric motor. Will be investigating...
SVreX
SVreX MegaDork
11/26/18 1:29 p.m.
Well, that’s largely correct.  They ARE two ways of saying the same thing.
A boring machine is bigger, heavier, and more accurate. It is designed for boring bigger holes than a drill press (think things like cylinder bores in an engine block). They also generally have much sturdier tables (for holding large pieces), and generally run heavier motors at slower speeds.
Often the table moves (which would be called a “line boring machine”)  for boring holes ... (wait for it)... in a LINE.
A line boring machine is closely affiliated with a vertical mill. Picture horizontal mill turned vertically.
Technically, drilling is making a hole, boring is a finishing process that enlarges a hole (with more accurate tolerances). Picture a cutting tool cutting the inside diameter on a lathe.
But I can’t tell you exactly how that relates to YOUR machine, because the table doesn’t appear to have the movement of a vertical mill.
I think you should just call it a B.A.D.  (Big azz drill)
AWSX1686
11/26/18 2:55 p.m.
I like it.
AWSX1686
11/26/18 2:55 p.m.
In reply to SVreX :
The other info there was good to know too, thank you.
oldopelguy
oldopelguy UberDork
11/26/18 3:59 p.m.
If the 3-phase motor works that might be a great candidate for a variable frequency drive to get you both speed control and single phase input, anda convenient on off control.  The Chinese ones on Ebay are only going down in price. I got one for my ironworker and it's been pretty flawless once I got it set up; you would actually be able to use more of the functionality.
AWSX1686
11/26/18 7:02 p.m.
In reply to oldopelguy :
Yeah, that's what my one friend was saying. I'm a little hesitant to trust an eBay part for that, but it would probably work. It would look way better that way too
puyQ5ilwnGirhmBk71pz9FQ1XDp4jyJTE1eyZvGwpHMeTA2o3VXaBYgqcawTxYwc
