Tom Heath
Tom Heath Production Editor
5/6/09 4:28 p.m.
mistanfo wrote: (yes, I am selling the project to the wife on the mileage aspect, and so far, she's buying it).
You realize the Flyin Miata V8 is getting ~35 mpg, right? Tough to beat that, regardless of cylinder count.
NOHOME
NOHOME New Reader
5/6/09 6:03 p.m.
http://www.streetperformance.com/part/gm-performance-parts/engine-block/786893-10051141.html
May be what you are looking for. Compact 60 degree v6 at 59 pounds/block weight and a set of aluminum heads from a FWD 3.4 should see you on the way.
ronbros
ronbros New Reader
5/6/09 6:31 p.m.
how about the 2010 Camaro V6, 300hp from thr factory!!
THX Ron
Dorsai
Dorsai New Reader
5/6/09 6:42 p.m.
Or the 6 in the Mustang the last few years, also good for 300 hp or so.
andrave
andrave New Reader
5/6/09 7:22 p.m.
oh also for the record there are 350z trans you can get off dealers that were replaced because they pop out of 6th gear (wouldn't be using 6th on a race car anyway) for a couple hundred bucks, and you can buy 95-99 maxima ENTIRE CARS for $500 with salvage titles but the engine runs fine.
so me thinks if that actually bolts up that would be a good solution. but youre still gonna have to figure out the flywheel, starter, clutch, and wriing situation. good luck getting a speedo to work. etc.
2002maniac
2002maniac New Reader
5/6/09 8:16 p.m.
What are those 2.8 60 degree V6's capable of? Werent they like 100-130hp stock? lol.
I'd like to see someone put a 4.3 crank/cam in a cut/welded/sleeved Ls1. Would be a ton of work to save maybe 40 pounds.
Here's an interesting article on 4.3 performance:
http://www.hotrod.com/pitstop/hrdp_0705_pitstop_chevrolet_v6_performance/index.html
P1PZy2k1vTKV8tiEj87mYlAQ98KDzTJAnqltNAeKXnzgYcju8kI31yWc4oBZIUHL
