akylekoz
akylekoz UltraDork
5/24/22 2:05 p.m.
After 5 track events I have finally bonded with my new car.  Let's play a game I call read these tires.
2008 Mustang GT, full fat version.  255/45/18 front 285/40/18 rear, 35psi, 34psi hot, 28 cold.
Tires are 2016 vintage Continentals with 340 tread wear ratings.
I painted a portion of each tire to see how far they were rolling over.
akylekoz
akylekoz UltraDork
5/24/22 2:06 p.m.
Drivers front.
akylekoz
akylekoz UltraDork
5/24/22 2:09 p.m.
Slight feathering, this is new.  Previous wear was more even.
akylekoz
akylekoz UltraDork
5/24/22 2:11 p.m.
Almost no paint left on this one.  This is the drivers rear.  What is up with the ridge towards the edge of the tread.
akylekoz
akylekoz UltraDork
5/24/22 2:16 p.m.
Rear, pretty flat.
akylekoz
akylekoz UltraDork
5/24/22 2:18 p.m.
Better shot of a ridge, out side rear.
akylekoz
akylekoz UltraDork
5/24/22 2:19 p.m.
And what it looks like in action.
red_stapler
red_stapler SuperDork
5/24/22 2:34 p.m.
akylekoz said: What is up with the ridge towards the edge of the tread.
That's abrasion graining, caused by the tire sliding.  Pretty normal to see on the edges of a street compound driven with any slip angle.
akylekoz
akylekoz UltraDork
5/24/22 2:48 p.m.
In reply to red_stapler :
That would make sense why I never saw this before.  Prior to my last track day I installed a T2R, the push/slide turned into grip and slip.
Some light chunking is also new, but it was a little chilly out and I was not patient warming the tires.
dps214
dps214 Dork
5/24/22 2:49 p.m.
Seems fine. Maybe a bit more pressure but on crap tires like those just keeping them from riding on the sidewalls is a win.
Tyler H (Forum Supporter)
Tyler H (Forum Supporter) GRM+ Memberand UberDork
5/24/22 2:54 p.m.
Those tires predated our last presidency and a pandemic.  They're from an entirely different era!  Zombie tires.  I predict that you're going to try to kill them, only to have them show up at another HPDE 28 days later.
akylekoz
akylekoz UltraDork
5/24/22 3:02 p.m.
In reply to Tyler H (Forum Supporter) :
Dood!   That is really spooky.  It's like you can read my mind.
ProDarwin
ProDarwin MegaDork
5/24/22 3:55 p.m.
My guess is you are just experiencing what it is like to use a 3600lb 300hp car to abuse 255s on the front.  Even with new 200TW I predict similar results, but with more grip.
What is a T2R?
dculberson
dculberson MegaDork
5/24/22 4:11 p.m.
Hey! Since when are Continental ECS tires "crap?" I resemble that remark.
Streetwiseguy MegaDork
5/24/22 4:12 p.m.
Based on the absurd amount of rubber left on those tires, you should be going faster.
akylekoz
akylekoz UltraDork
5/24/22 5:47 p.m.
In reply to ProDarwin :
It's the Torsen differential that comes in Boss 302 and other track spec cars.
300hp!  I'm 330 at the wheels, Ooo WOW, I know, not impressive in 2022.
akylekoz
akylekoz UltraDork
5/24/22 5:49 p.m.
In reply to Streetwiseguy :
I pulled of a 1:51 at Gingerman in this pig.  The abundance of tread is likely due to them being hard as a rock....and how slow I am.
akylekoz
akylekoz UltraDork
5/24/22 5:52 p.m.
In reply to dculberson :
Honestly these are not the best as dedicated track tire but they are hilariously fun in their current state.  I felt like I was in the spec tiger paw class.
A fresh set may not be bad at all, actually tempted to not go 200TW time and look in the 300 range.  It was that much fun.
rslifkin
rslifkin UberDork
5/25/22 8:25 a.m.
The ECS isn't crap, but those are the older Continental DW that preceded the ECS.  I don't remember those being nearly as good, nor holding up nearly as well as the ECS to stuff like track use.
dps214
dps214 Dork
5/25/22 8:39 a.m.
Yes. And crap might be harsh but none of the 300tw tires are really truly designed for track work. A friend of mine did one lap on Michelin ps4s on a heavy camber challenged car and they literally wore the Michelin logos off the sidewalls.
akylekoz
akylekoz UltraDork
5/25/22 9:33 a.m.
So, based on comments, how bad my tires are and how much of a pig my car is...could be worse Huh?
Until these are completely dead maybe a little more pressure in the front.  Drive harder to kill them quicker, and select a larger size front next time.  Next tires will likely be 275/40/18 front and rear.
adam525i
adam525i GRM+ Memberand Dork
5/25/22 10:10 a.m.
If you are sticking with that category of tire for your next set I'd take a hard look at the Firestone Indy 500, I feel like they'll hold up a bit better than the Conti ECS on a dry track and likely be quite a bit more affordable too.
Robbie (Forum Supporter)
5/25/22 10:25 a.m.
I was actually thinking you could go down in pressure a bit to let them roll a bit more.
Or am I seeing that wrong?
akylekoz
akylekoz UltraDork
5/25/22 10:58 a.m.
In reply to Robbie (Forum Supporter) :
The rears rolled right down to where the tread meets the sidewall but those are a 285 tire on a 9.5" rim so they are a little ballooned.   Fronts could maybe stand a little less pressure based on how far down the paint has worn, I'll go down a couple psi next time and see.
akylekoz
akylekoz UltraDork
5/25/22 11:01 a.m.
In reply to adam525i :
I'll probably end up with an endurance 200 like an RS4, just because I don't get out much and only put about 2k miles on a year.  Maybe this way I can wear them out before they age out.
I'm taking care of myself better so I don't wear out before I age out, not what I look for in a tire.
yHUrXxFAl0fnVawh762EAn5qO7aE6BMq32LIS5mKaPJd5SQzS8JB1WY09kVj6SwG
