singleslammer
singleslammer PowerDork
10/4/17 7:52 a.m.
https://kansascity.craigslist.org/wto/d/18-bmw-7-spoke-split-alloy/6283528161.html
They say the lug holes have whallowed but if I add a tapper and go lug centric, would that be good? I know this isn't the best idea but initial it would be just for autocross at the challenge. However,  I would like to use them for the street afterwards
Stampie
Stampie GRM+ Memberand SuperDork
10/4/17 8:00 a.m.
Could you make a hub centric ring on your table?
Donebrokeit
Donebrokeit SuperDork
10/4/17 8:01 a.m.
Looks like scrap metal to me.
singleslammer
10/4/17 8:12 a.m.
In reply to Stampie :
The centers are already too small by 1.5 mm. I would have to hone them out anyways with a drum sander.
But yes I could if the centerbore is were large enough
¯\_(ツ)_/¯
¯\_(ツ)_/¯ UltraDork
10/4/17 8:26 a.m.
Nope nope nope I wouldn't touch those- the only reason I'd even consider trying to get them back into usable shape would be if they were an especially odd pattern or offset that I couldn't find elsewhere, and BMW wheels are generally neither of those things.
GTXVette
GTXVette Dork
10/4/17 8:26 a.m.
Just NO, Keep looking
singleslammer
10/4/17 8:55 a.m.
Ok, good enough. Thanks gang
Patrick
10/4/17 9:01 a.m.
The only way I would consider is if they would clean up at the same bore as a wheel adapter that uses the shouldered lug nuts.  Like these.
Lug nuts
dont think there is enough meat there though and at least seller is honest
10/4/17 9:25 a.m.
What I might try is JB-welding and then re-machining the lug holes with a lug-centric taper, on top of using a hub-centric ring. Then inspect after every drive for a while and see how it holds up.
Zomby Woof
Zomby Woof PowerDork
10/4/17 9:43 a.m.
JB weld is a cheap epoxy and not suitable for something like that.
singleslammer
10/4/17 9:51 a.m.
Yeah, I wrote these off.
These however are very much a possibility. https://stlouis.craigslist.org/wto/d/18-stagger-oem-bmw-wheels/6275693843.html
These would fit damn near perfect.
Donebrokeit
10/4/17 10:11 a.m.
The second set looks to be in better condition.
stuart in mn
stuart in mn UltimaDork
10/4/17 10:13 a.m.
Not knowing which BMW you have, I'd confirm the rim width and offset will work on your car before pulling the trigger on them.
singleslammer
10/4/17 10:21 a.m.
These are actually for my Jaguar XJ that has 5x4.75 pattern. The offset I found works with my needs. I will have to use lug centric nuts though. I have done lots of searching, the .7mm difference has been proven to not be an issue.
Robbie
Robbie GRM+ Memberand PowerDork
10/4/17 10:28 a.m.
5x120 = 5x4.75
Someone (Jav?) did a proof on here that shows that changing the diameter of the stud from 1/2 to 5/8 changes the pattern by more than .7 mm. Its just that the 5 pattern is measured in a silly way. If it was measured in diameter of the stud centers, then everyone would be able to quickly tell there is no real difference.
RealMiniParker
RealMiniParker UberDork
10/4/17 11:07 a.m.
In reply to Robbie :
Huh? Since when are wheel bolt circles not measured on center?
Patrick
10/4/17 11:57 a.m.
5 lug is measured edge of one stud to center of diagonal one.
WonkoTheSane
WonkoTheSane GRM+ Memberand Dork
10/4/17 12:18 p.m.
Wha!?  Really?
10/4/17 12:35 p.m.
Err on the side of safety.
stafford1500
stafford1500 GRM+ Memberand HalfDork
10/4/17 1:26 p.m.
^^^That is the approximation for the actual bolt circle diameter of a 5 lug pattern. The stated pattern is the proper diameter of the bolt circle.
Jere
Jere Dork
10/5/17 1:07 a.m.
How do these people remember to breath?! All four wheels being lose to that point would have made an absurd amount of noise and car shake.... But they apparently just kept going surprise
6SET4yZsHv7s9fFdpLphgXZJJ7UpaSODLkqEAlMuk1MvV2z8nI5HubPvz6uXHy9p
