petegossett
petegossett GRM+ Memberand UberDork
4/21/13 8:01 p.m.
I had a chance to put my 225/45/15 Rivals to the test today and wanted to give my $0.02.
The short version: these things must be made of pixie dust, rainbows and unicorn farts, because BFG somehow combined the magical properties of velcro-like grip, the durability of iron, and a complete disregard of ambient temperatures, into a tire that communicates telepathically and recovers from over-the-limit excursions without any fuss.
My step-daughter and I co-drove at the autocross today, and combined had 14-runs total on good ol' USAF concrete. Despite ambient temps in the 50's, these tires gripped great right out of the gate and just kept getting better - think Toyo R888 without needing to get heat into them, or worrying about wear.
Here are a couple pictures from after the event. As you can see, there's not really any visible wear on the outside shoulder, and just a bit on the inside of each groove.
 photo 5D55D46A-982B-4800-AC8D-0E76DD113B2D-39071-00003851B859E497_zps8a0d6ae5.jpg
 photo 0224FA76-1F33-46E3-BBD2-1651147DA6C7-39071-00003851C081DDF1_zpsb0acfd2d.jpg
LainfordExpress
LainfordExpress HalfDork
4/21/13 8:52 p.m.
Nice, I have a set of these in the same size just waiting for the wheels to arrive so I can get them mounted up and go to work.
Vigo
Vigo UltraDork
4/21/13 9:25 p.m.
Pretty exciting stuff! I better go look up prices in the sizes i use..
mndsm
mndsm PowerDork
4/21/13 9:47 p.m.
Guess I know what my next set of meats is, pending review of the ZII.
wbjones
wbjones PowerDork
4/22/13 6:12 a.m.
Vigo wrote: Pretty exciting stuff! I better go look up prices in the sizes i use..
not all sizes are available yet ... more coming through out the summer
wbjones
wbjones PowerDork
4/22/13 6:26 a.m.
here is a copy of a tire test ( pulled from another site) that compares the Rival to some others (light weight FWD )
Tested the 205/50/15 BFG and the 195/50/15 Toyo yesterday. - Both at full tread, scrubbed in on skidpad and found tire pressures there (already knew on the Toyos and had a good idea on the BFGs since we ran a 12 run event on those the previous week). - My intentions this year are to run Toyos at events that are colder and use them as rains. Let's see what we found out... - Grissom was the site. - Car is setup for Toyos. YMMV and all that.
Method: - Ran simulated 2 driver, 3 run autocross in 3 different tire setup configurations with no setup changes other than normalizing the tire pressure: All Toyo, All BFG, BFG front/Toyo rear. It was very cold (40's most of the day) and we had a hard time generating heat for either tire on the rear of the car. - I did not run the setups in the order you see below. I have ordered them by slowest avg. to fastest avg. - I have driven hundreds of runs on this course configuration, so course learning isn't a factor here. Caveat: I know this is a very small run sample, but the test course I am very familiar with and all times for me on each setup was within .4, "driver noise" for me.
1) All Toyo impression - Car was phenomenal in the 6 cone slalom. Turn in and transition very good. By the second run the front was pushing mid corner and off, but turn in was still good. We all know heat management on the drive tires is crucial for these. Didn't spray the fronts down and could really tell. The full tread may have contributed to this as well. Avg. time: 44.002 Variance: .367 Hero run: 43.815
2) All BFG impression - Agree with Lugod that transitionally this tire is not as confidence inspiring. Especially with the rear of the car. We think lack of heat is what was really killing it for us and lower rear pressures were the key. Lowered the rear pressures on my last run in this run set and put the hero time down. Transition was much better and in hindsight should have lowered the rear pressure for the second run. Live and learn. Once a little heat was generated in the rear pair, it seemed like the rear grip was getting much better in transition. Same overall impression as everyone else for this tire: easy and forgiving tire to drive at the limit, noisy. Great overall grip. Doesn't punish you too much when over driven, but you can spin them up on corner exit if you use the loud pedal as an on/off switch and don't fully unwind the wheel first (little bit of co-driver coaching here) . Avg. time: 43.751 Variance: .352 Hero run (lowered rear pressures due to low heat): 43.552
3) Mixed setup (BFG front / Toyo Rear) - I present to you: Rear Toyo grip without the front Toyo mid corner push.
Very, VERY similar to the Hankook/Toyo F/R tire setup, but without requiring the high amount of heat the Hankook requires to work properly. Front was compliant from turn 2 on. Running the Toyo in the rear also made the car transition very well off the bat. Confidence in slalom was high, so more driver risk was evident. A "conservative" last run was the hero run here. Only .146 better than the best run on the all BFG setup. Average overall was better by .216, but IMO this was because grip was near instant in cold conditions. I would run this setup if the event was going to see cold temps (like low 60's or less with little surface temp). Avg. time: 43.535 Variance: .355 Hero run: 43.406
Overall impression / cliff's notes - All IMO: Overall grip of the BFG was better. Rear grip of the Toyo was better, quicker. It's down to driver feel and car setup, really. The times for us were mostly a wash and within the general realm of driver noise. The mixed setup was fastest on the time sheet overall, but not by much. It's going to depend on driving style and chassis setup/development to one tire as to which tire each competitor wants to use.
My codriver, who doesn't have a lot of autocross experience and is new to the car, preferred the Rivals only setup (although he too was quickest with the mixed setup). I was mostly undecided at the end, but leaning toward a mixed setup or all BFG. I think the instant grip of the mixed setup in cold conditions played a factor here. But I really liked the rear grip of the Toyo the best, and the front feel of the BFG the best. Again... driver style, preference, site type, etc. all play a factor here.
bludroptop
bludroptop SuperDork
4/22/13 6:40 a.m.
petegossett wrote: The short version: these things must be made of pixie dust, rainbows and unicorn farts, because BFG somehow combined the magical properties of velcro-like grip, the durability of iron, and a complete disregard of ambient temperatures, into a tire that communicates telepathically and recovers from over-the-limit excursions without any fuss.
This pretty much sums up our impressions after a couple of events on the Rivals.
GameboyRMH GRM+ Memberand UltimaDork
4/22/13 7:45 a.m.
Might go with these when I go to 225/45/15s, only thing I don't like about them is the asymmetrical tread pattern, if you swap left to right you're going to get a less-than-optimal tread pattern.
4/22/13 10:19 a.m.
If you swap left to right, they'll be exactly the same. BFG doesn't make a left and right version of the tire, just keep the outer on the outer and you're good. Now, flipping them on the wheel, that's not going to work as well...
Haven't tried the BFG yet, but I did have a chance to run a set of the Dunlop ZII yesterday. Not a great apples-apples comparison as it was a car that had never been on track before: our 2009 NC Miata with a fresh LS3 conversion. I had just run a few laps in my Targa Miata which has a similar power/weight ratio but a different tire size. In a 255/40-17, the ZII was a total sweetheart. Very forgiving and predictable, loads of grip with very good turn-in. Lap times were extremely good - on par with the pre-aero V8 Targa Miata running RA1s and a much more competition-biased suspension.
Can't say as many good things about the brakes.
Neckromacr
Neckromacr Reader
4/22/13 10:19 a.m.
GameboyRMH wrote: Might go with these when I go to 225/45/15s, only thing I don't like about them is the asymmetrical tread pattern, if you swap left to right you're going to get a less-than-optimal tread pattern.
Are you talking about dismounting and flipping it off the rim, or a cross rotation from the left side of the car to the right?
Vigo
Vigo UltraDork
4/22/13 10:42 a.m.
So far the only thing i wish i was seeing is a short 16" like a 215/45.
4/22/13 11:20 a.m.
Flipping it off the rim, I thought the treads were directional but Keith says they're not.
4/22/13 12:46 p.m.
They are a bit directional if you look at the picture on Tire Rack. But they're also definitely asymmetric. Asymmetrical AND directional means you need a left and a right tire design. But BFG doesn't do that, so the asymmetry wins in a dry performance tire. I wouldn't want to hit a lot of standing water with these in either direction.
This means you can change from side to side easily enough, but flipping on the rim isn't going to be ideal.
yamaha
yamaha UltraDork
4/22/13 3:23 p.m.
In reply to wbjones:
Oh look, quoted from our very own indy region pax civic driver......
4/22/13 3:36 p.m.
The Rival is a darn good tire. We have an initial report in the May issue, with some head-to-head testing in the next one.
Apexcarver
Apexcarver PowerDork
4/22/13 3:48 p.m.
I need new tires for my STS miata and I keep being torn back and forth between the Rival and the ZII starspec.
Car is also daily driven.
Am I right in thinking that the Rival might be a smidge faster, but the ZII easier to live with (rain and wear?)
4/22/13 4:33 p.m.
Never driven the Rival (as I said), but I would much rather be on a set of ZIIs if there was standing water anywhere in sight. That BFG tread pattern is just a nod towards "street".
The Star Specs were very good in wet conditions.
4/22/13 5:37 p.m.
Apexcarver wrote: I need new tires for my STS miata and I keep being torn back and forth between the Rival and the ZII starspec. Car is also daily driven. Am I right in thinking that the Rival might be a smidge faster, but the ZII easier to live with (rain and wear?)
The next issue you see might answer your question.
wbjones
wbjones PowerDork
4/22/13 8:09 p.m.
yamaha wrote: In reply to wbjones: Oh look, quoted from our very own indy region pax civic driver......
I thought he had a very good write up ... and it was obvious that he was willing to share info
jr02518
jr02518 New Reader
4/22/13 9:55 p.m.
Would "some one" Please have them make these in 14" sizes.
Really, I am begging.
yamaha
yamaha UltraDork
4/23/13 2:17 a.m.
wbjones wrote: I thought he had a very good write up ... and it was obvious that he was willing to share info
Its a good write up for sure, I'll admit that. Still dislike everything that particular car stands for.
wbjones
wbjones PowerDork
4/23/13 7:10 a.m.
jr02518 wrote: Would "some one" Please have them make these in 14" sizes. Really, I am begging.
when talking to the BFG engineers this past weekend ... I asked about 13" s .. ( and mentioned 14" s ) and they said they didn't even have a way to make them ... no molds that size ..
Bobzilla
Bobzilla UltraDork
4/23/13 9:41 a.m.
Don't worry... I put the pistons in that car.... it won't last.
aLv5YJz7G8iGdoDgZLWlRap0tUHWndh7HoSBLthkoFIFAMdjU4XIhqC1Yxh07XB0
