hobiercr
hobiercr GRM+ Memberand SuperDork
12/24/19 11:35 a.m.
12/24/19 12:30 p.m.
That just made my noise!
NOHOME
NOHOME MegaDork
12/24/19 2:12 p.m.
They are doing all the right things at this stage of the project when all you want to do is be "Done".
Wonder if any of the bodywork-in-progress is going to be put on YouTube?
Wonder what the color is going to be?
Assuming that a finished engine and gearbox have been waiting for some time so we wont have to live through that.
Pete
Robbie
Robbie GRM+ Memberand MegaDork
12/24/19 2:23 p.m.
The beginning alludes to some aerodynamic issues...
Crackers
Crackers Dork
12/24/19 2:32 p.m.
Now that all the fabrication work is done it feels like I'm going through a breakup.
NOHOME
NOHOME MegaDork
12/24/19 2:43 p.m.
In reply to Robbie :
You mean the blower wired backwards?
Knurled.
12/24/19 2:45 p.m.
They turned the radiator fan on and it was blowing out the cowl vent,.
Knurled.
12/24/19 2:46 p.m.
Except for the turbo they haven't got yet, or the charge cooler, or the interior panels and carpeting...
Dave M
Dave M HalfDork
12/24/19 2:52 p.m.
Oooh no! Now I'm going to have to stay up even later tonight!
Justjim75
Justjim75 Dork
12/24/19 3:28 p.m.
Am i the only one that got wood seeing the end of the road?  Well, theres the bus thing to kill 14 months.....
Robbie
12/24/19 10:59 p.m.
That's what I thought I saw.
The cowl vent will be high pressure at speed and if that is where hot engine bay air finds its easiest exit, that won't be good for cooling airflow.
SkinnyG
SkinnyG UltraDork
12/24/19 11:26 p.m.
I had a similar thing with the V8 Firefly cowl open to the engine bay and closed to the passenger compartment. Never overheated in traffic, but got a bit warm on the highway. Cowl pressure counters the rad flow.
Dave M
Dave M HalfDork
12/25/19 5:41 a.m.
I love this project but isn't it going to overheat?... Even without the bad engine bay airflow.
stroker
stroker UltraDork
12/25/19 9:12 a.m.
I want to know why any air at all would be going through the cowl louvers after they put that water collection pan under it...
wheelsmithy
12/25/19 9:28 a.m.
It wasn't sealed to the cowl. Just sort of a rain catch pan under it.
I totally did not think about the high pressure at the cowl. Good points above. Maybe there will be a big stonkin hole in the hood yet.
Knurled.
12/25/19 9:33 a.m.
Its okay.  From experience, that fan is garbage, and with all the not-room behind it once there is a turbo in the way, it will overheat mercilessly regardless.
BOM, prove me wrong!
Disclaimer:  I expect high horsepower cars to cool sufficiently when it is 95 degrees outside, wheras the BOM guys would need it to cool when it is about 20-25 degrees tops.  (If people want to compare gross HP vs. net HP on an even keel, then I will compare Fahrenheit vs. Celsius on an even keel too, dammit!  Also 25C is 77F)
BoxheadTim
12/25/19 10:56 a.m.
In reply to Knurled. :
25C is arguably when the UK starts to melt, at least based on my experience.
EastCoastMojo
12/25/19 11:47 a.m.
Holy E36 M3, they *removed* a bracket. Mind blown.
I did halfway expect them to roll the shell off camera, then cut to a fabricated paint booth and begin the body work on the other side of the shop.
There's still plenty of fettling left to do after paint. I expect at least another 10 episodes. cheeky
californiamilleghia
californiamilleghia Dork
12/25/19 12:09 p.m.
Probably right , but  I liked the fabrication , CAD patterns , angle grinders etc ,
Will they show the restoration of the Toyota running gear etc ?
bearmtnmartin
12/25/19 12:16 p.m.
I expect hey are now making some pocket change out of the series, so they have no reason to not post every step of the process. Why would they want to end things at this point?
EvanB
EvanB GRM+ Memberand MegaDork
12/25/19 12:20 p.m.
So they can be done with the project and have a finished car?
Streetwiseguy MegaDork
12/25/19 3:45 p.m.
I can see another half dozen episodes, or thereabouts.  There is still quite a bunch of work to do, then there is the first drive, then there is a whole bunch of stuff to do, then there is an extended drive over a few weeks, then there is a bunch of work to do.
Then, it won't be anywhere nearly as nice to drive as they had hoped, and it will get auctioned at whatever Barret  Jackson is called in England.
Knurled.
12/25/19 4:58 p.m.
Sometimes I think you deliberately make things more complicated than they need to be.
12/25/19 6:31 p.m.
This is like building an airplane.  90% done. 50% to go. Remember that.
FuzzWuzzy
FuzzWuzzy HalfDork
12/26/19 8:49 a.m.
Compared to years prior, it feels like they've released a lot more this year.
I believe they've not only started seeing some okay-ish compensation from the videos, but also would like to get it done and over with at this point.
rTGVmw5VH7kjaUYP7PpRsUn4qW47NUWjYVZzl1yasBh7MqseqiOgbF8M5zuIWzLb
