oldtin
oldtin HalfDork
9/11/10 10:42 p.m.
Any tricks for dealing with years of brake dust on alloy wheels?
Sonic
Sonic Dork
9/11/10 11:00 p.m.
strong degreaser and a pressure washer? The best wheel cleaner I've ever used is Mother's in the yellow bottle, and I only use it for really nasty wheels, otherwise some simple green or purple power and a pressure washer and a rag are all I've needed
Platinum90
Platinum90 SuperDork
9/11/10 11:06 p.m.
brake cleaner?
Derick Freese
Derick Freese HalfDork
9/12/10 1:16 a.m.
Brake dust doesn't seem to budge with my electric pressure washer. This is an application where elbow grease seems to go a lot further.
paul
paul Reader
9/12/10 8:46 a.m.
What's the finish on the wheels, clearcoat, machined surface, etc?...
oldtin
oldtin HalfDork
9/12/10 2:32 p.m.
probably a clear - hard to tell - they're nasty
mmk
mmk None
9/12/10 2:51 p.m.
The easiest way to clean up really nasty wheels is probably to use an acidic wheel cleaner. You just have to be a bit more careful careful with it (not leaving it on while having a long lunch or whatever). 'Wonder wheels' works for me, not sure if you can get that outside of UK though..
mtn
mtn SuperDork
9/12/10 3:15 p.m.
Spray some sort of cleaner on them and let it sit for a while. Then attack it with a Mr. Clean Magic Eraser. Seriously, that stuff is the best for brake dust.
jimbbski
jimbbski Reader
9/12/10 9:29 p.m.
mmk wrote: The easiest way to clean up really nasty wheels is probably to use an acidic wheel cleaner. You just have to be a bit more careful careful with it (not leaving it on while having a long lunch or whatever). 'Wonder wheels' works for me, not sure if you can get that outside of UK though..
I agree with the above. I use a mild acid that removes rust. Brake dust is partly steel & iron anyway.
iyIo5JCIPJ4j2bU9uPfW847DLA97W7cXLo02JDyM5VYMUz6OvVZhpNPx3tCKBgTz
