tuna55
tuna55 MegaDork
6/21/17 9:07 a.m.
I need measurements of the steering racks. PM me if you have one, and a tape measure, and a spare 15 minutes.
THANKS!
tuna55
tuna55 MegaDork
6/22/17 6:44 a.m.
uh oh. No takers?
Stampie
Stampie GRM+ Memberand SuperDork
6/22/17 6:45 a.m.
If it helps I'm interested in the same measurements.
MulletTruck
MulletTruck Reader
6/22/17 10:43 a.m.
I will see if the one I grabbed the power box from is still in the PYP yard this weekend.
MulletTruck
MulletTruck Reader
6/22/17 10:43 a.m.
Are you thinking of doing the power conversion?
tuna55
tuna55 MegaDork
6/22/17 10:44 a.m.
MulletTruck wrote: Are you thinking of doing the power conversion?
Yes indeed!
Knurled
6/22/17 11:47 a.m.
In reply to tuna55:
I'm not 100% about the Equinox or the Toyotas, but if you grabbed the rack from a VUE, you'd be doing a MANUAL conversion. The electrics are all in the column, the rack is just a manual rack with a power-like ratio.
Yes, you can run a VUE column stand alone.
tuna55
tuna55 MegaDork
6/22/17 12:48 p.m.
Knurled wrote: In reply to tuna55: I'm not 100% about the Equinox or the Toyotas, but if you grabbed the rack from a VUE, you'd be doing a MANUAL conversion. The electrics are all in the column, the rack is just a manual rack with a power-like ratio. Yes, you can run a VUE column stand alone.
In the case of the power being on the column, I'll take both the column and the rack.
MulletTruck
MulletTruck Reader
6/22/17 2:49 p.m.
The power part is separate from the column. Its a stand alone part. I am doing the conversion on my truck since the engine is in the back and I dont want to run lines to the front, plus the rack I have is a close ratio.
I have done a couple of these conversions and if you plan on autocrossing or doing any type of driving that really saws at the wheel it will over heat the unit.
Look into the Toyota unit. When you wire it up youdont need a controller like with the Vue. It goes into failsafe mode and is perfect where the Vue needs a controller. The ones on ebay from http://www.epowersteering.com/ work fine and the bigger kit they offer relocates the module from the unit it self.
tuna55
tuna55 MegaDork
6/22/17 3:19 p.m.
MulletTruck wrote: The power part is separate from the column. Its a stand alone part. I am doing the conversion on my truck since the engine is in the back and I dont want to run lines to the front, plus the rack I have is a close ratio. I have done a couple of these conversions and if you plan on autocrossing or doing any type of driving that really saws at the wheel it will over heat the unit. Look into the Toyota unit. When you wire it up youdont need a controller like with the Vue. It goes into failsafe mode and is perfect where the Vue needs a controller. The ones on ebay from http://www.epowersteering.com/ work fine and the bigger kit they offer relocates the module from the unit it self.
Yes I saw that. I need dimensions of the actual rack to see what's going to be close.
VD8ebzufDe42nYD2Qoj7soEtiVfrCys8XcW09zEA2MtmsbA8OCGBJRCMeubCRayo
