Dusterbd13-michael
Dusterbd13-michael MegaDork
1/8/24 2:49 p.m.
So, the factory intercooler on my baja turbo is busted and leaking.
I had picked up a hyperflow (made by turboxs apparently) aftermarket subaru top mount intercooler that i honestly hadn't planned on using anymore. I just hadn't sold it yet.
Well, i have it.
But is berkeleying HUGE.
before i go to all the effort to fit it, should i? This is a stock turbo car, that will have at most a bigger catless exhaust, header and uppipe and downpipe, and mild tune. At most. It IS a challenge car, but it is primarily a beater with a heater.
So, to install, or not and why? Im not turbo literate, and this is my first boost experience. So be gentle and spoon feed me please.
rustomatic
rustomatic HalfDork
1/8/24 7:44 p.m.
The answer is no.  Space, however, will more than likely dictate the reality you inhabit.
codrus (Forum Supporter)
1/8/24 8:00 p.m.
Pretty much all of your problems are practical ones involving making it fit, yes.  That said, a smaller intercooler with better airflow is probably better than a bigger one that's got lousy ducting.
RacetruckRon
RacetruckRon GRM+ Memberand SuperDork
1/8/24 9:40 p.m.
Dusterbd13-michael said:
This is a stock turbo car, for now.
FTFY
1/9/24 1:18 a.m.
This. Plus that one's only big for a TMIC, it would be a totally normal size for a FMIC.
fusion66
fusion66 Reader
1/9/24 6:44 a.m.
I expect  the larger intercooler will increase lag due to the increased volume of the system past the turbo (it has a larger chamber to bring up to pressure). How much and is it a meaningful amount? I have no idea.
mfennell
mfennell HalfDork
1/9/24 8:16 a.m.
I have been told by an OEM-adjacent engineer that is absolutely a thing with big intercoolers.  He also said that many of them were poorly designed as well (though I don't recall the details).
Paul_VR6 (Forum Supporter)
Paul_VR6 (Forum Supporter) UltraDork
1/9/24 8:48 a.m.
The only intercooler that is too big, is the one that won't fit.
z31maniac
z31maniac MegaDork
1/9/24 9:34 a.m.
Volume/lag was my first thought. That's more space the turbo has to pressurize before you get the goods.
Brett_Murphy (Agent of Chaos)
1/9/24 9:48 a.m.
There may be a bit of lag, but the turbo on the Baja is made to spool quickly. Since the Baja wasn't happy with sudden boost in the first place and you've never driven it while it was working properly, I'm betting you won't notice it and things will feel better overall.
Driven5
Driven5 PowerDork
1/9/24 12:19 p.m.
The 13T flows 390CFM at 14.7psi, which is 184 liters per second. How much intake volume is an 'oversized' intercooler actually adding?...
wae
wae PowerDork
1/9/24 12:24 p.m.
I think the answer is that, yes, an intercooler can be too big.  But that one is probably not.
11110000
11110000 Reader
1/9/24 12:54 p.m.
It takes a nonzero time to fill the extra volume, but remember that also means you have a reservoir during shifts (like an accumulator for intake air) to help minimize pressure drops.
Indy - Guy
Indy - Guy UltimaDork
1/9/24 1:22 p.m.
If you can make it fit, run it.
Curtis73 (Forum Supporter)
1/9/24 7:33 p.m.
Just how much bigger are we talking?  I'm a bit rusty on my Corky Bell, but I think he said no more than about 15% bigger than optimal.  At 20% bigger, you'll start to notice a bigger difference.  But, as Brett_Murphy pointed out, if it's undersized from the factory, you have to factor that in.  If this is 25% larger, but the factory intercooler was 10% too small, you're probably fine.
Can someone else with a Corky Bell book confirm that for me?
Boost_Crazy
Boost_Crazy Dork
1/10/24 3:00 p.m.
That's not too big, as long as it fits. The extra volume could create a bit of extra throttle lag, but the Subaru pipe routing is so short, it's likely still better than most cars. The increased size helps twofold. Not only is it physically larger with more cooling capacity, but the larger volume means that the internal velocity (and drag) is much lower. Your turbo won't have to work as hard and heat the air as much for the same manifold pressure. So the air going into the intercooler will even be bit cooler to start with.
Dusterbd13-michael
1/10/24 3:25 p.m.
Thanks y'all. Ill see if it'll physically fit the engine bay and engine of the baja. If so, game on!
Any considerations or things to pay specific attention to on install?
1/10/24 3:32 p.m.
will the hood close?
Dusterbd13-michael
1/10/24 3:37 p.m.
Umm....
Thats actually something i hadn't thought about. This thing is WAY thicker.
grover
grover GRM+ Memberand Dork
1/10/24 10:39 p.m.
Umm....
TNWSS
malibuguy
malibuguy GRM+ Memberand HalfDork
1/10/24 10:47 p.m.
In this particular situation effing send it ;)
maschinenbau
maschinenbau GRM+ Memberand PowerDork
1/11/24 8:50 a.m.
I'm here for early 00's era hood tilt spacers on a Baja
STM317
STM317 PowerDork
1/11/24 8:55 a.m.
Trim hood to fit and add STI scoop?
Dusterbd13-michael
1/11/24 9:02 a.m.
STM317 said:
Cut the hood and add an STI scoop?
I already bought one. You are reading my mind I also kept the flat hood off the parts car.
1/11/24 9:16 a.m.
STM317 said:
Trim hood to fit and add Hemi Dart scoop?
fixed
TCCsmZWLzoswlEJC55TRfGcc8x0efFUwznEFe6CjoPWJkomdy9Gca75y1jqfKhW9
