914Driver Dork
1/2/09 2:38 p.m.
My old 1.5 ton floor jack doesn't get to the top anymore. Little by little it has falling short of my desires until today when, figuring there was air in the system, I cracked open the filler screw thinking it was short on lubrication. Seems OK, so I close the thing up and now it's worse.
This is my only one so any help is appreciated.
Dan
Grtechguy
Grtechguy SuperDork
1/2/09 2:48 p.m.
Yes.
is the simple answer
what's the make/model?
Grtechguy
Grtechguy SuperDork
1/2/09 2:51 p.m.
a wee bit o' google.
answer #2 http://answers.yahoo.com/question/index?qid=20080607032541AApUUBG
Osterizer
Osterizer HalfDork
1/2/09 3:01 p.m.
914Driver wrote: My old...jack doesn't get to the top anymore. Little by little it has falling short of my desires until today when ... I ...screw ... short on lubrication. Seems OK, so I close the thing up and now it's worse.
Dirty boy! Dirty dirty boy!
914Driver Dork
1/2/09 3:23 p.m.
Grtechguy wrote: Yes. is the simple answer what's the make/model?
It's actually a 3-ton, the stickers are missing. I looked at H-F, Tractor Supply and NAPA and they all look the same, maybe different paint and stickers.
http://www.tractorsupply.com/webapp/wcs/stores/servlet/ProductDisplay_10551_10001_28128_-1______14297%7C14311%7C28128?listingPage=true&Special=false
mel_horn
mel_horn HalfDork
1/2/09 9:31 p.m.
Heh, heh, heh...he said "pump" and "saddle"...
If it looks like a NAPA jack it's most likely Sunex. My variation to the above is: 1. Release the jack (turn the handle CCW like you're letting it down) 2. Check and add fluid 3. Pull up on the saddle a few times 4. Turn the handle CW and put a load on it, see if it goes down
bigtoed
bigtoed New Reader
1/2/09 9:38 p.m.
Hey, give the jack a break. How old is it? I know I can't lift as much as I used to. As for getting it ALLLL the way up, I should check the viagra forums for that problem.
Wally
1/3/09 1:31 a.m.
On my craftsman you pull a rubber plug out of the lift cylinder and pump for a while.
noisycricket
noisycricket Reader
1/3/09 2:04 a.m.
If you can kill it... it can bleed?
dKkexIqzhGzj5M7huuOZDcYqjEgAL2wOwI819aZ6qcyXzLOiTZY84WFAzZHUGGwx
