stroker
stroker PowerDork
3/20/23 8:18 a.m.
It's attached to a Slant Six.  I'm no expert but I have no idea what it is...
Asphalt_Gundam
Asphalt_Gundam HalfDork
3/20/23 9:23 a.m.
Looks close to what I remember of the Brogwarner T18 4 speed w/granny low that was in my 87 f150
buzzboy
buzzboy SuperDork
3/20/23 10:10 a.m.
That would be an NP435
Curtis73 (Forum Supporter)
3/20/23 10:49 a.m.
Yup.  NP435.  Pretty easy to adapt to Ford, Chevy, Jeep, and Mopar since it was used by all of them.  IH even used them for a while.
Heavy duty, granny low.  Check for a tag on one of the bolts with an ID number like 435D or 435L.  The letter will tell you ratios.
https://www.novak-adapt.com/knowledge/transmissions/manual/np435/
WillG80
WillG80 GRM+ Memberand Reader
3/20/23 11:09 a.m.
Anybody know if the input shaft was the same between all applications? Or is it as simple as swapping the bellhousing?
Edit: never mind, the link above posted by Curtis explains that there are different diameter and splines on the input shafts.
3/20/23 5:02 p.m.
Not awful to change them IIRC.
SDpXqTNscLcUwJxLSbB2aGfYqGAEAUyl3iM7fG1PAbteqoJw4pkg9dwRclugD4LF
