96DXCivic
96DXCivic Dork
6/10/10 9:32 p.m.
My car just died as I was backing out of a parking space. Could it be the battery? What else could it be other then the battery?
Nitroracer
Nitroracer Dork
6/10/10 10:00 p.m.
If it was running and didn't stall from a clutch mishap I wouldn't bet on the battery in a 96' civic. That should be basic enough to run on the alternator.
Does it crank?
Timing belt, fuel pump, ignition issue, etc
96DXCivic
96DXCivic Dork
6/10/10 10:08 p.m.
No cranking. I backed out of the parking spot and I put it first and it felt like it stalled and then no restarting.
maroon92
maroon92 SuperDork
6/10/10 11:18 p.m.
it won't re-start, or it wont crank?
sounds electrical if the starter isn't turning over. if it cranks but won't fire, it sounds like a fuel pump or ignition problem (which could also be electrical).
96DXCivic
96DXCivic Dork
6/10/10 11:43 p.m.
Well we pushed started it and I made it back to the dorms and it seems to be running fine. Guess I will see if it starts in the morning.
spdracer315
spdracer315 Reader
6/11/10 9:05 a.m.
Check to see if your battery cables are loose. My truck did that once, and turned out the neg cable was loose, and it just lost connection going over a bump or something.
96DXCivic
96DXCivic Dork
6/11/10 12:08 p.m.
Well it would start this morning. It is a pretty old battery but I will check the battery cable.
Edit: oops Wouldn't start
96DXCivic
96DXCivic Dork
6/11/10 12:58 p.m.
If it is not the battery cable, what could it be? There is no clicking.
turboswede
turboswede GRM+ Memberand SuperDork
6/11/10 3:04 p.m.
Ignition switch?
dean1484
dean1484 GRM+ Memberand Dork
6/11/10 3:51 p.m.
Solinoid or a starter could be bad.
dean1484
6/11/10 3:57 p.m.
No click = Solonoid Click but no crank = starter
Click but no crank can also be low amperage to the starter.
I would load test the battery before you start swaping parts.
RossD
RossD Dork
6/11/10 4:09 p.m.
Bad ground connections?
HeavyDuty
HeavyDuty Reader
6/11/10 5:04 p.m.
Main relay? I agree, listen for a click as your turn the key to "run" but not start and that will narrow things down for you.
96DXCivic
96DXCivic Dork
6/11/10 5:08 p.m.
Ok so I jump-started the car and it ran fine and I let it run for 45 minutes. Turned it off and it won't turn back on. I think I need a new battery.
mcp001
mcp001 New Reader
6/11/10 9:59 p.m.
96DXCivic wrote: I think I need a new battery.
I think you are right.
AquaHusky
AquaHusky New Reader
6/11/10 11:50 p.m.
Mission accomplished!
dean1484
6/12/10 7:58 a.m.
Hummmmmmmm Could be an alternator. Did you load test the battery? Most part stores will do it for free.
bruceman
bruceman New Reader
6/12/10 9:02 a.m.
96DXCivic wrote: My car just died as I was backing out of a parking space. Could it be the battery? What else could it be other then the battery?
classic conditions for a cam belt to lose its teeth
Nitroracer
Nitroracer Dork
6/12/10 3:11 p.m.
My probe gt pulled that trick on me once, thank god it wasn't an interference engine. But it was finals week.
96DXCivic
96DXCivic Dork
6/12/10 6:00 p.m.
dean1484 wrote: Hummmmmmmm Could be an alternator. Did you load test the battery? Most part stores will do it for free.
I don't think it is the alternator since I ran it for 40 minutes after I jumped it.
YtwUKcTsqq7GSsf28o9hB85jGt4XdbxWtcwnwwKlBXplOoUoZHHaEbVmlN8OfdU2
