sanman
sanman HalfDork
12/14/14 1:54 p.m.
My sw20 mr2 with the 5sfe seems to smoke on startup when it sits for a week. It also idles high (2500 rpm. It smells like it might be oil more than coolant, but the smoke looks more white than blue. After about 5-10 min, the smoking gradually stops and the idle begins to lower itself down to 1100rpm or so. I am thinking it is the valve stem seals as they are know to be an issue on this motor at this age. Any other ideas? I am going to try and pull the plugs and take a look at them when I get a chance.
BoxheadTim
BoxheadTim GRM+ Memberand UltimaDork
12/14/14 2:46 p.m.
Yeah, I'd just pull the plugs and check.
Did you notice any loss of coolant?
sanman
sanman HalfDork
12/14/14 4:39 p.m.
Added some coolant not too long ago, but it was,my first time checking the level after I bought the car. I am keeping an eye on it at the moment to see if the hg is the problem, but I don't drive the car that much with the cooler weather and there are no leaks on the garage floor.
Slippery
Slippery GRM+ Memberand Dork
12/14/14 5:12 p.m.
Most likely valve seals. Have someone follow you and check if it smokes under engine braking.
XI5zaJ5Z6BaAFL157Ysx5vY90dpsev9OasrZIjGwVIVNt12Ky2sM6T9G8jUSo6aD
