mrdontplay
mrdontplay New Reader
2/11/09 6:39 a.m.
I'm looking for cars that cam factory with a turbo and a carb. I am wanting to do a blow through set up on my car and I'd like a carb that is already set up for it. My stock carb is a holley 5200 so one that will swap over easy would be nice. I have a 1.6L and I'm looking for about 150hp or 7lbs,which ever comes first.
Any other good info on this kind of setup would also be appreciated.
John Brown
2/11/09 6:45 a.m.
1979 Ford Mustang/Merucury Capri. 1983 Buick Regal, Riviera.
petegossett
petegossett GRM+ Memberand Dork
2/11/09 6:51 a.m.
I've seen a carbed turbo V6 Riviera from the early 80's, but never a 4cyl?
John Brown
2/11/09 6:58 a.m.
No I was just using turbo carbs in general. Finding an OE blow through is going to be hard enough as most of the OE turbo carbs are suckers.
Travis_K
Travis_K Reader
2/11/09 7:09 a.m.
Maserati biturbo is a blowthrough, along with that weird 50s kaiser thing with a flathead 6. The turbo regals used a normal 800 cfm q-jet, and it was a drawthrough setup.
Gonzo_Bmod
Gonzo_Bmod New Reader
2/11/09 8:21 a.m.
Was the Colt Turbo a blow through? What about the first generation 2.2 Dodge Turbos?
foxtrapper
foxtrapper SuperDork
2/11/09 8:52 a.m.
Corvair turbo was a blow-through, I believe.
Early SVO fox body Mustangs were turbo 4's, not sure if they were blow through or not.
The Dodges were fuel injected as I recall.
P71
P71 GRM+ Memberand Dork
2/11/09 9:05 a.m.
GT Turbo Mustang's were draw-through in the early years. The 3 years of SVO were EFI, as were all the later GT Turbo's and the TBird Turbo's, etc.
Factory blow-through carbs are nearly non-existent. Your best bet is to either have yours rebuilt to handle it, buy an aftermarket (4Bbl only unfortunately), or go EFI (MegaSquirt).
John Brown
2/11/09 9:06 a.m.
Or build an isolation bonnet. Pressurize the whole carburetor.
P71
2/11/09 9:47 a.m.
^ That would also work.
belteshazzar
belteshazzar Dork
2/11/09 9:59 a.m.
What setup was the first TTA?
P71
2/11/09 10:03 a.m.
EFI for the Buick V6 based ones. I'm pretty sure the craptastic 301 V8 was a draw-through.
aircooled
aircooled Dork
2/11/09 10:20 a.m.
foxtrapper wrote: ...Corvair turbo was a blow-through, I believe....
Nope, it's a sucker. Used a goofey carb that was used on the 6 cylinder Corvette.
16vCorey
16vCorey SuperDork
2/11/09 10:36 a.m.
Early turbo Starquests were carbureted.
ww
ww Dork
2/11/09 11:46 a.m.
I assume you mean the Mitsubishi Starion/Dodge Conquest?
JFX001
JFX001 HalfDork
2/11/09 12:03 p.m.
What about the early Escort EXP Turbo's?
m4ff3w
m4ff3w GRM+ Memberand Dork
2/11/09 2:07 p.m.
ww wrote: I assume you mean the Mitsubishi Starion/Dodge Conquest?
Starquest is a common contraction for Starion/Conquest
erohslc
erohslc New Reader
2/11/09 2:14 p.m.
Just FYI, you can repurpose a cheap aluminum pressure cooker into a pretty nice Grassroots pressurization bonnet, they are already built for sealing and holding 1 Bar of pressure at high temp, and come in different sizes. Mount the carb through the lid; use some flat plates and a bunch of JB Weld to get the inner and outer mounting surfaces level and flat on a curved lid, then use a holesaw for the center hole(s). Weld a pipe onto the 'pot' section in a convenient place for the pressurized air to enter. The rotate and lock mechanism allows you to remove the pot for easy access to the carb.
Carter
oldopelguy
oldopelguy HalfDork
2/11/09 2:22 p.m.
erohslc wrote: Mount the carb through the lid; use some flat plates and a bunch of JB Weld to get the inner and outer mounting surfaces level and flat on a curved lid, then use a holesaw for the center hole(s).
Seems like a lot more work than just mounting the carb through the bottom of the pot?
Not a half-bad scheme, though, and certainly priced right.
thatsnowinnebago
thatsnowinnebago GRM+ Memberand HalfDork
2/11/09 2:25 p.m.
You'd be cookin' with that setup. www.instantrimshot.com
ultraclyde
ultraclyde New Reader
2/11/09 3:55 p.m.
Couple running Starions on Atlanta Craigslist yesterday...
http://atlanta.craigslist.org/search/cta?query=starion&minAsk=min&maxAsk=max
erohslc
erohslc New Reader
2/11/09 5:21 p.m.
If you mount the carb in the bottom of the pot, it's a real bitch to get to. On the lid, it's right out there ....
Carter
2/11/09 5:58 p.m.
^^^ good point!
jimbbski
jimbbski New Reader
2/11/09 8:59 p.m.
20+ Years ago I looked into turboing a car using a blow through carb set up. I even have some info on how to modify any carb for blow through. Better to modify the carb then to enclose it. Remember you have to run a number of lines, hoses, tubes, and a throttle cable throught the bonnet. All sources of air leaks.
At the time these was no grassroots sources for converting a car to fuel injection that never came from the factory with it. Now with Mega Squit and what all these is no reason at all to use a carb, none!
The only common car to use carbs & a turbo was the early FOX chassis cars, Mustang & Fairmont came with 2.3L turbos with suck through carbs.
alex
alex Reader
2/11/09 9:15 p.m.
I love turbos, I love carbs. Somebody translate the jargon in this damn thread for somebody like me who's not accustomed to both on the same motor.
Nfgm5G0lNFhr1KrvkFtszJLuvnIofPmMlBw1onsDfocLehucbS4SxsUzthOWb2TC
