Treb
Treb Reader
11/19/10 8:28 p.m.
There's a simple part I need for my wife's Fiat Spider -- the old pieces crumbled in my hands. 35-year-old rubber, not so durable.
The usual suspects have them backordered.
And I'm stubborn sometimes about making things.
Simple enough piece -- it's the bumper between the door and the door jamb. Basically, it's supposed to soak up some of the vibration caused by scuttle shake, I think.
Kind of a triangle, rounded on one end. 16mm thick. I used the fragments of the originals to figure out the dimensions & made a model of the original in balsa.
My plan, to the extent that I have one, is to make a mold in plaster and then cast new pieces in urethane. I'm all right with the plaster moldmaking; but any suggestions on the rubber/urethane stuff?
Methods/suppliers/material properties/warnings/etc appreciated.
Thanks Matt
RoosterSauce
RoosterSauce Reader
11/19/10 8:38 p.m.
I used a urethane kit from McMaster-Carr to make myself an engine mount. It worked great, and was easy to use. As a bonus, the stuff smelled like grape. I used the Flexible Urethane #8644K18. Of course, you can choose whatever hardness and tensile strength you think is appropriate for your bumper thingy http://www.mcmaster.com/#urethane-casting-compounds/=1l1oz5
skeze
skeze New Reader
11/19/10 8:58 p.m.
also if you are super cheap and wanna go at the home depot way you could always fill your mold with that tool grip dip stuff it comes in many colors,or you could even use that blue gasket silicone stuff...I've made silly balls with both of these products to great affect so a little door stopper should be a no brainer
Knurled
Knurled GRM+ Memberand HalfDork
11/19/10 9:02 p.m.
I've made rubber bits by making a mold out of JB Weld and then using Permatex Right Stuff to make the part.
Ziploc bag material makes a great mold release agent.
Not great for really complex pieces, but worked great for what I needed to make, which was, oddly enough, a rubberbumper. I cast a wingnut in place for something to thread onto.
procainestart
procainestart Dork
11/20/10 12:22 a.m.
Get this book? http://www.amazon.com/cast-small-metal-rubber-parts/dp/0830698698
benzbaron
benzbaron HalfDork
11/20/10 1:08 a.m.
Silastic J is a silicone RTV that you can cast. My pops used it in jewelery makings so it must be easy to use.
Treb
Treb Reader
11/20/10 10:56 a.m.
The plan, right now: plaster mold, johnson wax as a MRA, and starting with RTV/handle dip type things. (i.e. locally available and cheap). Depending on results, I might try the McMaster-Carr urethane.
Treb
Treb Reader
11/23/10 5:24 a.m.
First try: Right Stuff.
Not bad -- though there are a lot of voids in the part (poor form on my part -- ptobably better not to move the nozzle very much, just let the stuff flow a little.) Also, 36 hours later, it's still liquid in the center, so that will take a while, I guess.
44Dwarf
44Dwarf Dork
11/23/10 6:36 a.m.
Treb. Where are you from? Your profiles empty... I have a few gallons of 2 part RTV i'll never use but it not the lightest and considered hazardus in non cured form so shipping sucks.
Treb
Treb Reader
11/23/10 8:48 p.m.
Ooh, I'll have to fix that.
Lexington... Kentucky. (Named for the battle of, but that's a different story)
Thanks for the offer, 44Dwarf.
Matt
93gsxturbo
93gsxturbo HalfDork
11/23/10 10:04 p.m.
If you have access to a bell jar and a vacuum pump, once you pour the part, put it in the bell jar and pull a vacuum. It will draw all the air out and leave you a part with no or very small voids.
We used to make silicone molds for casting low temperature alloys like pewter. The vacuum method looks crazy because the silicone will actually appear to boil as the air is sucked out, but it works great!
44Dwarf
44Dwarf Dork
11/24/10 6:15 a.m.
Vacuum degassing will work but only with two part mixes.
motomoron
motomoron HalfDork
11/25/10 2:20 p.m.
I'd find some big rubber suspension bump stop in a junk yard, bandsaw it into shape and finish on a belt sander.
If I had to make a bunch I'd carve a plug, make a silicone mold, and cast them in urethane.
02Pilot
02Pilot Reader
11/25/10 2:53 p.m.
3M Window Weld is a handy material for stuff like this. I've used it to fill voids in motor mounts and other rubber bushings. Cheap and readily available, plus one-part and pretty easy to work with.
gfFnEQRpZ97WlTSgZQgYylbnvvZfGpsYAldgy3CaogklEA1abdwJ3MHqnmCQbJfN
