I have a set of snow tires for the wife's prius and I need to find a set of wheels. The tires are 15" diameter. The prius uses 5x100 bolt spacing, 45mm offset, 54.1mm hub bore. What other cars came with compatible wheels?
Here is a link for sizing which also includes the important center bore size.
http://www.roadkillcustoms.com/hot-rods-rat-rods/Wheel-Bolt-Pattern-Cross-Reference-Database.asp?LugCount=5&StudSpreadInch=4.75&StudSpreadMM
Bookmark the site. I am sure that I picked it up off GRM years ago.
Second gen Neon alloys are all 15's. They are about 35mm offset. Cavaliers are closer to 40mm I think. Not sure on center bore.
95 and newer Cavaliers had 15X6 steel wheels that you should be able to pick up pretty cheap. napa site says they have a 60.9mm bore diameter, which would mean they wouldn't be hub centric, which isn't a big deal as long as you tighten the lug nuts evenly.
