chada75
chada75 HalfDork
12/11/20 7:06 p.m.
In reply to captainawesome :
That's how I approach modify Cars and Trucks. Rather have a stock ride with the best wheels/tires on it than wiz bang parts with cheap shirty tires.
12/12/20 1:24 p.m.
On a dollars per track mile level, are Toyo RA1s still the king of decent performance while wearing like granite?
Tadope
Tadope New Reader
12/17/20 11:08 a.m.
Yeah, that makes sense, but I think that a lot of people are here to build cars. not just grab something and drive it. Although the grab and drive crowd is definitely real.
but I think most tuners are into modifying and doing things with mechanical bits. Also wheels/tires can easily be swapped out at any time. So it's not really a permanent thing like suspension.
codrus (Forum Supporter)
codrus (Forum Supporter) GRM+ Memberand UberDork
12/17/20 11:13 a.m.
Either RA1s or NT01s.
Tadope
Tadope New Reader
12/17/20 2:32 p.m.
Pretty sure r comps are nowhere near affordable
12/17/20 2:47 p.m.
Suspension isn't permanent, it's fast to swap out and the higher end stuff needs rebuilt on a regular basis anyway.
12/17/20 3:40 p.m.
In the long run you'll spend less money using tires that are designed for the race track on a separate set of wheels than you will ripping up street tires in an environment they weren't designed for.
The absolute cheapest way to run tires at the track is to get race car takeoffs for $25 each.  This usually requires having an "in" at the shop that is throwing them away, though.
12/17/20 5:51 p.m.
Plus, tires are probably the cheapest consumable, depending on chassis.
Then again most of the track day horror stories/maintenance nightmares I've seen involve pads that last two sessions, rotors that last one before they crack, wheel bearings that are a constant juggling factor (but prying the seals back with a dental pick, flushing out the grease, and replacing with high temp synthetic grease might make 'em last half a season), and all sorts of regular inspection and lifeing out of bushings, spindles, you name it.
My rallycross maintenance regimen looks to be pretty tame in comparison.  Anyway, that's why a good number of people see the C5 as a really cheap way to get track time, because all of the consumables are fairly robust so you aren't spending two weeks of evenings prepping the car for the next weekend...
Tadope
Tadope New Reader
12/20/20 3:34 p.m.
Yeah, last track problem i had was pads that hadn't broken in or bedded properly or something...
they were track pads. But they just ended up dying completely by the last session. Really put an end to the day.
But also I hear you about the racecar takeoffs. I already found some r comps locally all four for $60. very little tread left, but berkeley it. Only problem is someone beat me to the purchase :(
goingnowherefast
goingnowherefast GRM+ Memberand Reader
12/22/20 7:15 p.m.
No not even close. Maybe a decade ago.
RS4's take that prize now.
H0qrpjImHuFVDjl1pJ0BtgagaWNBQ4g9o1Xh6LRqjcNTOVTQ9DatEa6Fs6EXrRqc
