aussiesmg
aussiesmg SuperDork
5/6/10 4:46 p.m.
I know that the 350 and 400 have the same bellhousing bolt pattern but does the 3.8 Camaro share the same bolt pattern?
Steve
oldopelguy
oldopelguy Dork
5/6/10 6:49 p.m.
No, the 3.8 Camaro (usually called a 3800) is the smaller 60* v-6 bolt pattern. (Same as the 2.2 and 2.5 4-cylinder too.)
The earlier 3.8L From the Grand National and Cutlass and such is the standard BOP bolt pattern.
aussiesmg
aussiesmg SuperDork
5/6/10 7:36 p.m.
OK I need a bellhousing for a SBC 406 to a T5 with an internal slave, any ideas?
Knurled
Knurled GRM+ Memberand Reader
5/6/10 7:48 p.m.
Probably easiest is to use a generic aftermarket throwout-bearing style slave cylinder.
I say this, not having tried it...
Why does it have to be internal?
Streetwiseguy Reader
5/6/10 8:43 p.m.
Is this going in a Camaro, and if so, does it need to have the trans laid over a bit like the 3rd gen cars? If so, hit the wreckers for the bellhousing/master/slave setup from 84-93. 82 and 83 had Muncie boxes and mechanical linkage.
Edit; At least I think they are internal slave, but i'm doubting myself now.
aussiesmg
aussiesmg SuperDork
5/6/10 8:49 p.m.
It is in the S10 challenger, the T5 trans is from a Camaro but other than shift alignment no need for it to be laid over. I have the Camaro bellhousing but the external slave is in my way
I need the internal slave so I can route headers into the space that the external slave sits between the frame and the block.
novaderrik
novaderrik New Reader
5/6/10 9:02 p.m.
just get whatever Chev bellhousing you can find and run an aftermarket hydraulic throwout bearing. the one thing to look out for is if you are running a 168 tooth flywheel, then you will need a bellhousing out of a truck or something that had the same flywheel and use either a stock cast iron nose starter, an aftermarket mini starter, or a late model permanent magnet starter like the ones that they started using in the 4.3V6 and V8 trucks in the mid 90's. if using an aftermarket mini starter or a small 153 tooth flywheel, make sure that the block is drilled for the straight across starter bolt pattern- a lot of 350's and 400's in the 70's were only drilled for the staggered mounting pattern,
aussiesmg
aussiesmg SuperDork
5/6/10 9:18 p.m.
I have the staggered hi torque starter and the 168 tooth flywheel so all I need is a bellhousing and that throwout bearing style slave.
So any truck bellhousing for a T5 will work?
Any brand name for the bearing preferred?
OJyslpBZvR4fyGZl82rTo8y0WxLrth2aZswFpkaJ1innrCi8Qvm9xNuFQ9rSAiPZ
