1 2 3 ... 5
10/26/21 9:58 a.m.
Why reveal a new model at a car show when you can show a half-hour film dedicated to the creation of that new car?
That’s exactly what Chevrolet has done for the reveal of the C8-chassis Corvette Z06. That film, “Putting the World on Notice,” debuts today, October 26, at 12:00 p.m. Eastern and can be viewed at chevy.com/Z06 or at …
STM317
STM317 UberDork
10/26/21 11:08 a.m.
ChrisTropea
ChrisTropea Associate Editor
10/26/21 11:10 a.m.
Wow the LT6 will rev to 8600. Anyone else have thoughts on the Z06 so far?
10/26/21 11:16 a.m.
And here it is:
A few quick facts:
  • 5.5-liter N/A LT6 flat-plane crank V8 good for 670 horsepower at 8400 rpm and 460 lb.-ft. of torque at 6300 rpm backed by an eight-speed dual-clutch with a shorter final drive.
  • Standard reconfigurable rear spoiler
  • Available Z07 package can provide "734 pounds of downforce at 186 mph, more than any Corvette ever," plus adds carbon-ceramic brakes
  • Electronica limited-slip differential
  • Launch control
More pictures to come in a few.
STM317
STM317 UberDork
10/26/21 11:18 a.m.
A red corvette isn't exactly original, but here's what I came up with on my first run through the configurator. Red with red calipers. I wanted the carbon wheels, which automatically includes the ZO7 package. Fabric seats with red belts. I like the two tone option available on the convertible:
STM317
STM317 UberDork
10/26/21 11:28 a.m.
Brown coupe with bronze wheels, tan interior and glass roof isn't bad either, although I wish the wheels and interior were a bit closer in color:
10/26/21 11:38 a.m.
Z07 package:
LT6 engine:
"Standard" Z06:
Driven5
Driven5 UltraDork
10/26/21 11:43 a.m.
Looks (and sounds) like a fantastic 'drivers' car for magazines and low mileage accumulation collectors... I'm substantially skeptical of that engines long-term durability and maintainability as a higher mileage accumulation enthusiast car though. I wonder how long until you can get similar kit with a cross-plane engine trim.
10/26/21 11:45 a.m.
Given Ford's experience with the flat plane Voodoo, it'll be interesting to see if the General releases the LT6 as a crate. GM seems a little more crate-happy than Ford overall but it's my understanding that flat planes are not easy to just drop in. Even JW Automotive Engineering had all sorts of trouble with the flat-plane DFV when they tried to use it for endurance racing.
STM317
STM317 UberDork
10/26/21 11:55 a.m.
Optional full carbon wheels are 20X11 in front and 21X13 in the rear and reportedly save 41lbs of unsprung mass:
adam525i
adam525i GRM+ Memberand Dork
10/26/21 12:01 p.m.
In reply to STM317 :
Do they come in a chrome finish though? lol
10/26/21 12:33 p.m.
130+ horsepower per liter!  Criminy.
j_tso
j_tso HalfDork
10/26/21 12:46 p.m.
I remember John Horsman(?) said the DFV was only designed to run for 4 hours and Cosworth wasn't interested in developing it for Le Mans.
The C8.R had some vibration issues at its first Daytona 24 but I think they've solved those problems.
10/26/21 12:48 p.m.
I'll have to go back to Racing In The Rain and see what Horseman says specifically, but vibration problems were the big complaint.
10/26/21 12:49 p.m.
And on a big engine, too. All the tech developed to make ICE super-efficient and clean has some nice tradeoffs.
ProDarwin
ProDarwin MegaDork
10/26/21 12:52 p.m.
Cool.
There are still not SCCA legal, right?
TR7 (Forum Supporter)
TR7 (Forum Supporter) Reader
10/26/21 1:32 p.m.
Sooo.... no more pushrods? Is it now worthy of competing with imports (I say in jest).
10/26/21 1:35 p.m.
Corvette dropped pushrods once before. It didn't stick :)
I think I need to find dimensions of this critter.
RossD
RossD MegaDork
10/26/21 1:50 p.m.
GM also put the starter in the valley of a V8 once before too.
Is that still the standard bellhousing pattern?
10/26/21 1:55 p.m.
It has got to have bores in the 100mm+ range to have enough valve area to make that power.  Normally bores that large translate poorly for efficiency. 460 ft-lb is roughly 83-84 ft-lb/liter, about normal for a very well sorted, much smaller DOHC engine.
Interesting.
06HHR (Forum Supporter)
06HHR (Forum Supporter) Dork
10/26/21 2:12 p.m.
In reply to RossD :
Looks a bit different, here's the GenV LT1 from 2014,
Google-fu is failing me right now for a rear shot of a C8-spec LT2 EDIT:  Found one!  Slight difference from the LT1 bellhousing pattern, which itself is different from the Gen IV LS engines.
ProDarwin
ProDarwin MegaDork
10/26/21 2:13 p.m.
Why?  In the Honda K48 thread they are estimating 700hp using stock K24 heads which have an 86mm bore.
Is there a rule of thumb on total bore size vs. maximum power?
tuna55
tuna55 MegaDork
10/26/21 2:16 p.m.
Really cool engine, though I am sad to lose the neat packaging of the pushrods, which, obviously, a mid engined car does not need.
The car is still pretty ugly.
10/26/21 2:52 p.m.
Engine specs? Engine specs:
10/26/21 3:21 p.m.
Bore diameter reduces detonation resistance.  More distance between the spark plug and the ends of the chamber means more time for knock to happen.
Is the "K48" 50-state compliant for 2022 emissions?  That would seem to equate to two 350hp engines, not 200hp-ish like are emissions certified.
1 2 3 ... 5
TBCF8Y7FHgajE4kyUrMoMtcJrc2ufT8iFbmW07kqj5K5kffJv9Ojyr6DXH3gm62e
