Teh E36 M3
Teh E36 M3 SuperDork
12/30/18 7:01 p.m.
Not affiliated, but anyone have any experience with these?
https://clamptitetools.com
Seems like a pretty cool solution to having the right size hose clamps for any application.
Woody
Woody GRM+ Memberand MegaDork
12/30/18 7:04 p.m.
I have one, but I have only had mixed success with it. There are times and places when you don’t have enough space to use the tool as intended. I like having it for emergencies though.
NordicSaab
NordicSaab Dork
12/30/18 7:19 p.m.
I have one as well. It generally works well and I agree with your comment above. The "trick" is to use thinner wire than you think you will need and "double" clamp it.
dean1484
12/30/18 7:44 p.m.
I have wanted to get one of those. Looks like a good addition to the emergency tool kit.
Jumper K Balls (Trent)
Jumper K Balls (Trent) PowerDork
12/30/18 7:51 p.m.
I bought one thinking it would be a cool way to attach hoses on prewar cars. I thought it would look more era appropriate than a worm gear clamp.  I think I used it exactly 10 times, three of those involved more blood than I liked and one involved me removing a piece of stainless wire that went all the way through my index finger.  I ended up putting it in a GRM new years gift box so I wouldn't be tempted to use it again.
I use my safety wire pliers to do the same thing and bend the twisted end in a loop. Still looks vintage but far less tricky and easier to do in tight spaces
Also, using a narrow piece of wire is pretty much the worst way to clamp a hose.  Small stressed area is pretty much a knife to a soft hose, especially after repeated heat cycles.
Looks cool though.  I dug the look of the finished clamps.
AnthonyGS
AnthonyGS HalfDork
12/30/18 7:51 p.m.
I’ve started using the same style crimp clamps as found on Audi’s and VWs with great success and you can get them in bulk cheap.  I use them for any small hoses (vacuum, heater, fuel etc).  For large stuff (radiator or intake) I use OEM style spring clamps or old fashioned worm clamps.  I can provide a photo if that helps.  For the VAG clamps they make a couple of crimp tools but they aren’t expensive.
EDT
EDT New Reader
12/30/18 7:53 p.m.
I’ve used mine quite a bit for both cars and aircraft and love it. I always double wrap the wire and have never had a failure and think it looks much better than a regular hose clamp. Though, like everyone else has said, it doesn’t work in tight spaces, you’ve got to be able to flip the tool over.
M2Pilot
M2Pilot Dork
12/30/18 9:49 p.m.
IIRC there was a thread on here within the past year or so with a lot of love for it.  Seems Keith Tanner,among others, think it's great.
benzbaronDaryn
benzbaronDaryn SuperDork
12/31/18 12:27 a.m.
I bought one to do a clean install on the breather for my Harley, I used soft aluminum wire, the stainless is way more than I needed and difficult to use. Think some fat copper wire would look nice also.
Ranger50
Ranger50 UltimaDork
12/31/18 6:13 a.m.
I’m using these on my future challenge vehicle. The pound of wire is multiple feet from Harbor freight for $9..... sure beats $0.20/ for E36 M3ty hose clamps or $2 for t bolt clamps...
44Dwarf
44Dwarf UberDork
12/31/18 7:43 a.m.
I have one an almost never use it except on fuel injection line inside the Ducati gas tank.  A real pain to do the few inside the tank but worm clamps don't seem to work well there and the pinch clamps normal used with injection don't fit do to the Ears blocking the o-ring to tank seal area.
Kramer
Kramer Dork
12/31/18 8:07 a.m.
The spring clamps are popular because they allow expansion and contraction while keeping a constant tension.  Worm gear clamps often need tightening after a few heat cycles to prevent weeping. I'd imagine wire clamps would, too.
5ZA39Zr75igKInaatAqKQ2F5Wkcjmr79kBPk7GPjba7QZCuU4hHXzof01Nu7UuAZ
