Curtis
8/30/19 6:35 p.m.
codrus said:
Seafoam is the stuff you run through the intake while the car is running makes a ton of smoke, right?  Isn't that for cleaning carbon deposits in the combustion chamber, rather than oil sludge in the crank case?
I guess you could drain the oil and fill it up with brake cleaner, but... :)
Yes, but it also works as an oil additive for this purpose.  At least according to the destructions on the can.
Yx1plwhZOQgswtDnbJGTVpAkeY0R982uBxF32Sw4BZlsUPTm02u8amsDGxYRVsUE
