I can't catch a break with this berkeleying car.
Runs perfectly at sea level. As we got into Colorado, started to get weird. LEAN in almost all conditions, and often won't return to full lean when decelerating in gear, instead chooses to burble along in the 12-13:1 range.
The exhaust is getting REALLY hot due to the lean condition, which isn't making the trans tunnel pleasant.
It's also trying to overheat now. I'm unsure if this is because of the lean conditions making it run hotter than normal, or if the cooling system that almost works TOO well at sea level isn't sufficient up here? Had to pull off the road 3 times yesterday on my way up to Estes Park.
I can get it to drive OK at best by adding +15% fuel trim everywhere, but it's still not "right." It idles like E36 M3 like that, and the AFRs still aren't reacting correctly on boost/part throttle situations.
Any ideas? I'm completely confused. Trying to get some datalogging to send back to my tuner, but wondering if there's anything "normal" about all this that i'm missing. The car is VE tuned, and if that were messing up, i'd expect it to be RICH, not LEAN.
Details:
2004 mazdaspeed Miata
550cc injectors
Haltech Platinum Sport 1000
Bigass 55mm Mishimoto radiator w/ shroud and fans.
I'm sure the fans aren't the best, but it's having no problems bringing the temps down at a stop @ idle.
I'm also having some problems coming to terms with the difference between absolute and gauge pressure. My gauge is still showing 10psi max boost, though the vacuum numbers have changed with elevation. Haltech is now recording no more than 6.5psi, though is still SOMEHOW showing almost 22inhg of vacuum at idle.
Both the gauge and Haltech MAP are T'd into the same line off the intake manifold.
I really hate this berkeleying car. It's ruining my vacation/wedding/honeymoon.
