Motojunky
Motojunky New Reader
4/18/24 9:06 a.m.
Say your sh*tbox Subaru RallyCross car needs a clutch... clutch manufacturers all suggest a break in period of gentle driving for several hundred miles. The car isn't street driven (not tagged) and will see well under 100 miles all season - none of them gentle.
My thinking is that I'll drive it around a little to put a couple of heat cycles in it and send it. It only does a launch and a single 1-2 shift per run. It'll be fine.
What do/would you do?
Ranger50
Ranger50 MegaDork
4/18/24 9:20 a.m.
Idle on jackstands dragging the brakes with some occasional shifting?
4/18/24 3:43 p.m.
I've heard of pro drifters doing some procedure that involves standing on the brakes and slipping the clutch for some period of time.
Slippery
Slippery GRM+ Memberand PowerDork
4/18/24 3:48 p.m.
In reply to Motojunky :
I would try and call the clutch manufacturer. I had this exact issue back in the day with a ClutchMasters clutch, I called and they gave me a slightly altered disc material that needed no break in.
Motojunky
4/18/24 4:05 p.m.
That reminds me of something. I had a former friend who worked unloading new cars from trains for delivery to dealerships. He used to brag about putting new 5.0 Mustangs in 5th and dumping the clutch at a standstill. All this time I felt bad for the purchasers of those new cars. Maybe he was just breaking in their clutches?
I'll do the Googles and see what I can find about the drift guys. Thanks.
Motojunky
4/18/24 4:06 p.m.
Stock class - has to be an OEM type replacement. That's really just an excuse for me to say that I already ordered the clutch and didn't think to consult the manufacturer in advance. :)
4/18/24 4:50 p.m.
From what I can find, clutch break-in is similar to brake pad break-in, in that it's about wearing in the surfaces and completing some heat cycles without overheating the material. Obviously it's a lot trickier to do that with a clutch though...
4/18/24 5:31 p.m.
I figure just drive it.  It's not like you are asking your non street driven vehicle to make the clutch last another 200,000 miles.  And it doesn't matter if it is a little juddery.  And if it slips, maybe the transmission will last longer.
Slippery
4/18/24 5:55 p.m.
Stock oem clutch? Go and have fun. No need to break in. Rip through the gears as soon as you are done changing it.
I thought you had an upgraded disc with kevlar or something.
wvumtnbkr
wvumtnbkr GRM+ Memberand UltimaDork
4/18/24 7:38 p.m.
I have never broken in a clutch.  I have beat the piss out of oem type clutches from the first shift.  No issues.
This includes racecars.
Go beat on it.  You won't notice any difference.
4/18/24 7:55 p.m.
I've had 2 new clutches and they both only got a hint of street driving for break-in, neither had any problems. One was a stock-spec clutch and one was an Exedy Stage 1.
lUcpDk12qAFnkvH9cshwLnQDSAMf69fc43AV2opuyAltPhotnfmIdvI3bEM6trDR
