NordicSaab
NordicSaab Reader
11/14/15 10:40 a.m.
This may be a strange request, but what (common, i.e. available under $1000) FWD car has the most low end torque? Considering an odd build...
Mid 90's Cadillac STS with a 4.6L Northstar was my first guess
kb58
kb58 Dork
11/14/15 10:42 a.m.
First generation Toronado maybe. 425 ci and 475 ft-lb of torque. Could be hard to find but a heap might be free.
JtspellS
JtspellS SuperDork
11/14/15 10:50 a.m.
Easier find might be any sort of Bonneville/GM S/C 3800?
NickD Reader
11/14/15 10:55 a.m.
NordicSaab wrote: Mid 90's Cadillac STS with a 4.6L Northstar was my first guess
Cadillac STS was RWD. You're thinking of the DTS. But a first-gen Toronado would be most-torquey FWD, or possibly a 7th-gen Cadillac Eldorado (They had a Caddy 500 in them). Most common would probably be any of the GM 3800S/C cars though.
flatlander937
flatlander937 GRM+ Memberand Reader
11/14/15 11:04 a.m.
Impala SS with the LS4? More common and best of all no Northstar.
Cotton
Cotton UberDork
11/14/15 11:14 a.m.
Olds Aurora had 260tq and can be had cheap.
Ranger50
Ranger50 PowerDork
11/14/15 11:15 a.m.
4.0 Olds Aurora?
drdisque
drdisque Reader
11/14/15 11:22 a.m.
If you're looking for a modern transverse drivetrain the LS4 is the way to go. Just pull an entire subframe out of a wrecked V8 G/W-body Impala SS/Grand Prix GXP/Monte Carlo SS.
The FWD Northstar doesn't make as much torque is just as big and is harder to work with. The only advantage is that you can get one wired for OBD-I. There were actually two slightly different versions of the FWD Northstar. The "base" version was tuned to run on mid-grade and made less power but about the same torque and the "high performance" version was just tuned to make more power up high. They were very similar.
If you want something more compact, the Series III Supercharged 3800 (L32) is the best option - although they were hard to find. The Series II L67 is almost as capable and much easier to find and has more technical resources out there.
Older engines - yeah, the Olds 500 from the 7th gen Eldorado and the 455 from the Toronado were torque monsters, but keep in mind that they were longitudinally mounted, not transverse, so they would be difficult to package into a modern FWD car.
If you're opposed to using a GM that doesn't leave many options. The '95-'02 Lincoln Continental used a 4.6L DOHC Mod motor mounted transversely, but the stock transmission could barely handle it and they were huge. It would be theoretically possible to mount a modified MTX-4 out of an SHO onto one to get a manual.
If you're up for building an engine, then you could look at SHO engines, VQ35's, VG30's, J32/35's, etc.
sethmeister4
sethmeister4 SuperDork
11/14/15 12:30 p.m.
4th gen (95-99) Maxima was decent for a V6. Rated at 205, I think. Can be increased relatively easily, and they can be found cheap and parts are plentiful in junkyards because they made tons of them.
sethmeister4
11/14/15 12:31 p.m.
Also, 5th gen Maximas have even more torque, but a sub $1000 one might be harder to find.
NordicSaab
NordicSaab Reader
11/14/15 12:40 p.m.
To provide more details, I'd prefer biger displacement for the purpose of turbocharging. Gen 3 sounds like a great option, but I'm prefering the sound of the 4.0 Aurora Engine.
patgizz
patgizz GRM+ Memberand PowerDork
11/14/15 12:42 p.m.
The only 90's rwd caddy was the fleetwood(brougham) until the catera came around. STS, deville, eldo all FWD. Adding to the confusion there was a FWD fleetwood as well early in the decade.
Under a grand probably northstar but due to their issues I'd opt for a supercharged regal/gp/bonnie. If for driveline donor especially, smaller package and toss on a 3.4 pulley and blow up northstar numbers
novaderrik
novaderrik UltimaDork
11/14/15 12:55 p.m.
the supercharged 3800 is the way to go.. they are common as dirt- you can get running but rusty Grand Prix GTPs for $500 around here- and respond well to slight modifications. they are a nice simple 90 degree OHC v6, so there are no huge and expensive timing chains/belts to worry about- just a single little chain on the front of the engine under the water pump that never wears out.
i find the LS4 to be intriguing, but everyone i know that has ever had one got sick of the transmissions blowing up on them out of nowhere.. but upgrade parts are also readily available for them- if it bolts to or into any other LS engine, the odds are pretty good that it will fit on this,too..
you couldn't pay me to own anything with a Northstar or it's Aurora offspring in it.. partly because the cars they come in are too freakin complex, but mostly because nothing is cheap or easy on those engines.
oldeskewltoy
oldeskewltoy UltraDork
11/14/15 2:20 p.m.
What about 6th Gen (67-70) Eldorado? 1970 was 550#/ft of torque
Toyman01
11/14/15 2:30 p.m.
oldeskewltoy wrote: What about 6th Gen (67-70) Eldorado? 1970 was 550#/ft of torque
QFT.
Woody
Woody GRM+ Memberand MegaDork
11/14/15 2:34 p.m.
Toyman01
11/14/15 2:40 p.m.
In reply to Woody:
Those are either a Olds 455 or a 403.
TheEnd
TheEnd New Reader
11/14/15 2:51 p.m.
If you get a s/c 3800 get a Regal GS.
dansxr2
dansxr2 Dork
11/14/15 3:38 p.m.
88-92 Probe GT's/ MX-6 GT's can be had for less than a grand. A manual boost controller and a ECU Chip will net you 200-220whp & close to 300ft/lbs on a stock engine.
captdownshift
captdownshift GRM+ Memberand UltraDork
11/14/15 4:07 p.m.
MkIII or early MKIV TDI. Toss in injector nozzles and a chip and see roughly 300lb-ft from a 1.9L
yupididit
yupididit HalfDork
11/14/15 4:17 p.m.
SHO because they sound great.
captdownshift
11/14/15 4:18 p.m.
Are rough 2.4 turbo pt cruisers entering that price range?
Will
Will SuperDork
11/14/15 4:23 p.m.
The 99-02 Lincoln Continental had a special FWD version of the 4.6 DOHC that makes 275 hp and 275 lb-ft. Might not be the most torque, but I'm willing to bet you could find some pretty cheap.
sesto elemento
sesto elemento Dork
11/14/15 5:27 p.m.
4g63t or a 2gr with a trd blower?
old_
old_ Reader
11/14/15 5:55 p.m.
I just bought a 98 regal gs for 1k. It had a bad s/c coupler ($20 part that makes the s/c clack loudly at idle/startup) so the guy thought the s/c was shot. Other than the horrific 90's GM playskool interior its not a bad car. I found that premium fuel really wakes it up.
0XiOYfJ1RrE9IcboDT4x1iS3QVcPMdivNzD2gjko55Vzrvl1vmRPA1iI1pxps9zf
