Gearheadotaku
Gearheadotaku GRM+ Memberand Dork
10/8/11 6:38 p.m.
While we're talking wiring, has anyone ever seen an epoxy that conducts electricity? I can't solder worth a squat, thought this might work.
Trans_Maro
Trans_Maro Dork
10/8/11 6:54 p.m.
Yup, we used it on Beech 1900D propeller blade shanks when I was working as an AME.
It was just Devcon 5 minute epoxy mixed with powdered aluminum. I can't remember the ratio but it went by weight.
The mix was conductive when it was cured. We used it to pot the blade bearings to the propeller shanks and provide a conductive path for static discharge.
The blades were kevlar / fibreglass composite with an aluminum spar in the middle. They were painted with conductive paint and the epoxy served to bed the steel bearings to the conductive painted blade shank and provide a current path.
I'd bet you can buy powdered aluminum online somewhere.
Shawn
fritzsch
fritzsch Reader
10/8/11 6:55 p.m.
I always thought something like a hot glue gun but like really strong glue, that was conductive, would be a very handy invention. I dont know of anything though
TRoglodyte
TRoglodyte HalfDork
10/8/11 6:59 p.m.
Trans_Maro wrote: Yup, we used it on Beech 1900D propeller blade shanks when I was working as an AME. It was just Devcon 5 minute epoxy mixed with powdered aluminum. I can't remember the ratio but it went by weight. The mix was conductive when it was cured. We used it to pot the blade bearings to the propeller shanks and provide a conductive path for static discharge. The blades were kevlar / fibreglass composite with an aluminum spar in the middle. They were painted with conductive paint and the epoxy served to bed the steel bearings to the conductive painted blade shank and provide a current path. I'd bet you can buy powdered aluminum online somewhere. Shawn
That powdered radiator sealant stuff? Ohm meter to verify?
Taiden
Taiden Dork
10/8/11 7:08 p.m.
Learn how to solder.
My tips:
  1. get solder that doesn't require flux (most solder is like this)
  2. let your soldering iron heat up
  3. keep your tip tinned (load it with solder and let it bake hard to the tip)
  4. give your tip a wipe with a damp paper towel to remove all soot before continuing
  5. apply heat to the part, and apply solder to the part, do not apply solder to the iron
  6. if the part doesn't seem to get hot enough, put a bit of solder on the tip and try again. liquids conduct heat better than solids
  7. when you're done, put a nice blob of solder on the tip and store it like this
It's worth it to learn how to solder
fasted58
fasted58 SuperDork
10/8/11 7:33 p.m.
what exactly have you been attempting to solder? Like most other skills it's acquired through practice and more practice.. a lot like welding.. and folks learn more every day. Soldering is not that difficult, plus what Taiden said.
I found using a small block of wood behind the joint (if possible) helps stabilize the wires to be soldered and aids in heat transfer to the wire joint, my .02
Woody
10/8/11 7:42 p.m.
Yes.
I bought a used Snug Top Miata hard top with a rear window defroster. The wiring harness plugged onto male terminals that were epoxied to the grid on the glass, and one of them had come off. I wrote to the company and they sent me a tiny bit of the stuff in a plastic container, for free. From what I understand, it's really expensive because it has actual gold in it. I think i may have been a Permatex product.
Teh E36 M3
Teh E36 M3 HalfDork
10/8/11 7:44 p.m.
Taiden wrote: Learn how to solder. My tips: 1. get solder that doesn't require flux (most solder is like this) 2. let your soldering iron heat up 3. keep your tip tinned (load it with solder and let it bake hard to the tip) 4. give your tip a wipe with a damp paper towel to remove all soot before continuing 5. apply heat to the part, and apply solder to the part, do not apply solder to the iron 6. if the part doesn't seem to get hot enough, put a bit of solder on the tip and try again. liquids conduct heat better than solids 7. when you're done, put a nice blob of solder on the tip and store it like this It's worth it to learn how to solder
There is way too much goodness here.... for what it's worth, I always keep my tip tinned. Keeps out the soot.
MG_Bryan
MG_Bryan Reader
10/8/11 8:15 p.m.
This plus buy hemostats. They are great heatsinks and cost next to nothing
NOHOME
NOHOME HalfDork
10/8/11 8:49 p.m.
Yeah, we use the stuff at work . The price will convince you that learning to solder is the way to go. Gotta sotre it a -50C if you want to keep it for any time. (arrives on dry ice) The cleanlines and general prep make soldering seem trivial. You dont want to try and run any high current through the stuff since it is more resistive than solder.
Chas_H
Chas_H New Reader
10/8/11 8:54 p.m.
I've used silver filled epoxy with good success to re-attach wires to defroster grid on rear windows. It's expensive.
Trans_Maro
Trans_Maro Dork
10/8/11 10:25 p.m.
In reply to TRoglodyte:
Not rad sealant, we just had a white plastic uart bottle with "Powdered aluminum" on a label. Can't remember where we got it but we used so little with each mix that we never needed to re-order in the 8 years I worked there.
Yes, we verified with an ohmmeter when we were done. This wouldn't work with electronics since the resistance was in k-ohms.
I missed the "can't solder worth a damn" part. It's really not that hard, you just need practice.
Shawn
Taiden
Taiden Dork
10/8/11 11:51 p.m.
My final tip is to put your heatshrink over the offending wire BEFORE soldering them together.
Hocrest
Hocrest HalfDork
10/9/11 5:44 a.m.
Taiden wrote: My final tip is to put your heatshrink over the offending wire BEFORE soldering them together.
You need to stand over my shouldeer every time I'm soldering to remind me of that
Taiden
Taiden Dork
10/9/11 8:07 a.m.
MG_Bryan wrote: This plus buy hemostats. They are great heatsinks and cost next to nothing
Where does one buy roach clips, I mean hemostats?
oldeskewltoy
oldeskewltoy HalfDork
10/9/11 3:29 p.m.
My tip about heat shrink.... Thermafix Plus dual wall, it has an adhesive on the inside that seals the join making an enviromental seal
unevolved
unevolved Dork
10/9/11 5:36 p.m.
The biggest thing about soldering is using a good iron. It's incredibly frustrating if your iron doesn't get hot enough. With a good iron, it's more or less brainless.
M2Pilot
M2Pilot Reader
10/9/11 5:44 p.m.
You should be able to get powdered Al from a pyrotechnics supplier. Sometimes these suppliers are at gunshows.
dlmater
dlmater GRM+ Memberand New Reader
10/9/11 5:51 p.m.
unevolved wrote: The biggest thing about soldering is using a good iron. It's incredibly frustrating if your iron doesn't get hot enough. With a good iron, it's more or less brainless.
+1
I struggled with soldering many years ago using a cheap iron. A friend gave me a good iron and it made a huge difference for me.
Taiden
Taiden Dork
10/9/11 6:09 p.m.
For what it's worth, I have a nice analog temp controlled station, and a $5 walmart Weller soldering iron.
I use the Weller most often.
fasted58
fasted58 SuperDork
10/9/11 6:27 p.m.
Basic how to solder and shrink wrap from PM:
http://www.popularmechanics.com/cars/news/4213013
Radio Shack is an easy place to find tools and supplies but buy the better stuff, it's worth it. Clamp jig is nice but not always usable like under dash so be ready to improvise. A block of wood can make a good back up in a pinch.
I solder and shrink wrap all crimp terminals too.. forks, rings, slots etc. Makes for a stronger connection. I seen too many wires twist and weaken at the connector barrel end.
Gearheadotaku
10/9/11 6:35 p.m.
..so then I solder through the tubing?
Dr. Hess
Dr. Hess SuperDork
10/9/11 6:40 p.m.
Learn to solder. It is not hard. Surely there's a youtube on it.
I used a $5 crap shack soldering iron for 2-3 decades. Same tip. And it was a major component of the tools I earned a living with for 7 years. Finally, when I had to build a Megasquirt based ECU from scratch with all miniature components, shown here:
I broke down and bought a professional solder station. It is very nice, but still, most of my work is done in the shop with a HF soldering gun or my old crap shack iron.
My point being that you don't need the $100 solder station. The cheap soldering iron will do you just fine. Just learn how to use it. And buy the smallest ROSEN CORE solder you can get at crap shack. It will make all of your work easier.
JoeyM
JoeyM SuperDork
10/9/11 6:55 p.m.
Dr. Hess wrote: Learn to solder.
neat practice project: DIY digital watch
bHhRWFzwq6WSoVXWOrhA5DABoAYP6b1wNM9BGQc4L7rCOycATSHw3sudHru7HADl
