Lof8 - Andy
Lof8 - Andy GRM+ Memberand UltraDork
2/10/24 8:50 p.m.
can the corrugated plastic material used in yard signs handle the heat from a radiator?
accordionfolder
accordionfolder UltraDork
2/10/24 10:19 p.m.
In reply to Lof8 - Andy :
That's what my supra had and was raced with for a long time.
Lof8 - Andy
2/10/24 10:23 p.m.
Perfect.  Thanks!
2/11/24 12:23 a.m.
It will not only work for ducting in front of the radiator but even behind it, I used coroplast to patch up a puller radiator fan shroud and it's held up for years.
EvanB
EvanB GRM+ Memberand MegaDork
2/11/24 12:45 a.m.
Yep that's what I used for a long time, sealed with duct tape.
Rodan
Rodan UltraDork
2/11/24 8:25 a.m.
I use it with good results on our Miata.
lotusseven7 (Forum Supporter)
lotusseven7 (Forum Supporter) Dork
2/11/24 8:51 a.m.
Political signs and foil tape work well.
akylekoz
akylekoz UltraDork
2/11/24 9:00 a.m.
Also great for underbody smoothing, if you can find the big sheets.  Our recycling center had lots of it.
accordionfolder
2/11/24 9:54 a.m.
Where are you guys getting them? This is actually fairly timely because I need to duct a radiator as well.
j_tso
j_tso Dork
2/11/24 10:05 a.m.
In reply to accordionfolder :
Everywhere pretty soon, it's an election year.
accordionfolder
2/11/24 11:06 a.m.
In reply to j_tso :
Well, right, but do you guys just go ask the political headquarters or? I've gotten them here and there but wouldn't mind a nice backlog of them for a few projects
Rodan
Rodan UltraDork
2/11/24 11:14 a.m.
The best time is just after an election... lots of political signs end up in the trash.
5mm corrugated plastic sheet is also available on Amazon, though it's not super cheap for what it is.
Ranger50
Ranger50 MegaDork
2/11/24 11:38 a.m.
Ask to volunteer to distribute signs and never deliver? Use a fake name of course...
accordionfolder
2/11/24 11:41 a.m.
In reply to Ranger50 :
Lol, sounds like a plan
rallyxPOS13
rallyxPOS13 GRM+ Memberand Reader
2/11/24 2:22 p.m.
Gorilla Glue and chopsticks to link multiple panels together.  From an article long ago by Dave Coleman: https://motoiq.com/wrench-tips-17-election-day-ductwork/
Racebrick
Racebrick HalfDork
2/11/24 2:51 p.m.
Any signs posted on public property are free to the public.
theruleslawyer
theruleslawyer New Reader
2/11/24 3:34 p.m.
If you need more heat resistant there is an aluminum version people use for spoilers, etc sometimes. Alumilite- https://www.laminatorsinc.com/sign_product/alumalite-standard/
camopaint0707
camopaint0707 Reader
2/12/24 7:12 a.m.
yeah, this is actually quite common
DeadSkunk  (Warren)
DeadSkunk (Warren) UltimaDork
2/12/24 7:31 a.m.
My old NB Miata would run cold for quite awhile in the winter, so I had a coroplast sheet slipped in between the rad and its support. Never melted or even got particularly flexible from the heat. It's pretty good stuff for free, and there'll be an unlimited supply starting this summer.
RevRico
RevRico GRM+ Memberand MegaDork
2/12/24 8:19 a.m.
Your local idiots still use coroplast? I'm jealous. For the past few line ups we've had, everybody is just using plastic film, which isn't nearly as durable or useful.
QuasiMofo (John Brown)
QuasiMofo (John Brown) GRM+ Memberand MegaDork
2/12/24 8:30 a.m.
We used sign material in our bulk powder coat process as a medium to keep our hooks and hangar grounds clear of yield. Our ovens ran at 325f and 375f and the material never failed. Eventually the buildup would get so heavy we would have to replace the pieces.
moto914
moto914 GRM+ Memberand New Reader
2/12/24 9:56 a.m.
PLASKOLITE 0.157-in T x 48-in W x 96-in L White Corrugated Plastic Sheet. From Lowe's @ $35 to cover my pergola.
Alumilite- thanks @ theruleslawyer good to know for my aircooled under car air flow.
Stampie
2/12/24 10:31 a.m.
accordionfolder said:
In reply to j_tso :
Here in Jacksonville there's a city law that anyone can remove political signs that are placed in the public right of way.  I hit the voting precinct right before voting closes and get as many as I want.
paddygarcia
paddygarcia GRM+ Memberand HalfDork
2/12/24 3:42 p.m.
At least for the branded version:
Melting Point: 160° C (320° F)
Boiling Point: Not applicable
Flash Point: Not applicable
Auto Ignition Temp: 570°C (1058°F)
https://www.coroplast.com/wp-content/uploads/Coroplast-standard-sheets-SDS-06-07-19.pdf
Snrub
Snrub Dork
2/13/24 12:55 a.m.
Any tips for attaching it in under body application?
JoJUTTiHRwOABqFaxjfYkUt0YeAV8IzQk7nQw6VotEXSdK7N1NA5daAlIfklSfFS
