Vigo
Vigo UltimaDork
10/30/18 11:02 p.m.
How far did you back off the rockers? Running for only 3 or 4 seconds and then fading out with a backfire at the end sure sounds like your lifters pumping up from oil pressure and holding all your valves open.
dean1484
10/31/18 7:18 a.m.
Have you verified that you have not wiped the cam?  This can happen on initial start up. Why cam lube is so important. Especially on SBC.
AngryCorvair
10/31/18 12:08 p.m.
i'm down with Vigo
Twisted46
Twisted46 New Reader
10/31/18 8:46 p.m.
I will try backing the rockers off more
Fladiver64
Fladiver64 New Reader
10/31/18 8:53 p.m.
In reply to Twisted46 :
Run them out at least a full turn, too loose at this point is not going to matter. This is not final valve adjustment time. Something else I hear you saying is it idles for a short bit. The last thing you want with a new cam is running at idle, get the rpms up to 2500 or whatever your cam company wants. Get the rpms up and check timing that it is not too far advamced, then work on your cam break in. If the valve train is noisy from being too loose, your not going to hurt anything at those rpms. Idling a new cam is a good way to wipe out new lobes.
Twisted46
11/1/18 8:26 a.m.
In reply to Fladiver64 :
I will try that. I too am very worried about cam health at this point. And while the motor has ran for less than 30 seconds total I have been turning it over a lot.
Twisted46
11/2/18 9:28 a.m.
Quick update, I backed rockers off another 1/4 turn or so and i noticed the motor got harder to turn by hand. I set the timing at 12BTDC, rotor on the leading edge of post #1. It took a few tries with the clutch and starting fluid but I fired up and idled on its own until I pulled ignition after 10-15 seconds. I have a friend coming over to help me set timing and rpm then i will put water in it and finish cam break in.
Hopefully that is all it was I am back to having some PR wiggling but no noticeable noise
AngryCorvair
11/2/18 11:34 a.m.
"got harder to turn by hand" = "valves seating properly and holding compression in cylinders"
i'd back em all off another 1/4-turn and get the rest of it ready to run long enough to break in the cam.
good work!
Vigo
Vigo UltimaDork
11/2/18 2:01 p.m.
Congrats!! Now you can get to the fun part!
Robbie
Robbie GRM+ Memberand UltimaDork
11/2/18 3:09 p.m.
clicked on this thread to see if you were running yet, was not dissapointed!
Great job.
Fladiver64
11/2/18 4:58 p.m.
+1 on the back the adjuster s off another 1/4 turn . We have all been in your shoes, good job sticking with it, feels great went it finally works!
Twisted46
11/2/18 10:12 p.m.
Thanks again guys. I will back them off some more. I guess new lifters are easy to overtighten.
I'll get a video up so you all can see your hard work pay off.
Also watch for more posts about my build of you guys arr interested in an SBC powered 260z track car. Actually driving this thing with the V8 is going to be nuts!
Twisted46
12/13/18 8:52 p.m.
Sorry it took so long, engine broken in with new oil. Sounds happy to me:
https://drive.google.com/open?id=1AovLfAtmztKdfcW1GYPYeF5wHJ2F3Uv0
Vigo
Vigo UltimaDork
12/14/18 8:40 a.m.
Sounds good to me!!yes
A 401 CJ
A 401 CJ GRM+ Memberand Dork
12/14/18 10:11 a.m.
Good lord.  What’s that thing weigh?  2000#?  It’s gonna pound on late model Vettes in the straights at least.
Twisted46
12/15/18 2:08 p.m.
Car weights about 2300 with the SBC in it. Come Spring I will get some 30+ rolls recorded as I am guessing anything under 30 will just result in tire smoke. Right now I could probably spin tires in 5th a 60 with how cold it is.
mt8sSXXqZIHpWhZqq6nhV2aHhICyg1rDDUtb5DwDQcwj0JPZWsfIu5K1FolxBGI4
