wae
wae Reader
11/26/13 9:54 p.m.
Oh, if we're looking for alternate solutions with an element of danger...
When I did the timing belt service on the Oddity that we used to have, I seem to recall that I jammed the breaker bar in there somewhere and then hit the ignition switch to use the starter to break it loose.
Unless that would have caused the transmission to go out, it worked great.
Kenny_McCormic
Kenny_McCormic UltraDork
11/26/13 10:10 p.m.
In reply to chaparral:
I prefer to put the jack under the breaker bar.
chaparral
chaparral GRM+ Memberand HalfDork
11/26/13 10:42 p.m.
In reply to Kenny_McCormic:
I've done that on other parts (especially on diesel engines at my first summer job) and thought it would work here. It didn't.
The key is that the jack drops very quickly when the valve's open. It's a swing of a 1200-lb hammer pivoting about the rear axle.
Jerry From LA
Jerry From LA Dork
11/27/13 1:34 a.m.
Streetwiseguy wrote: The breaker bar is the least of your problems with pulling the crank pulley on a Honda. They have a magic bolt that requires 400 foot pounds to remove after torquing to 130, so the most important thing is the holder tool for the front pulley. Or a 3/4" impact wrench will do the job...
Amazing what a bit of galvanic corrosion will do. Anit-seize on the reinstall.
bZQTEQyLZGHb4eLEFTf1LXms9741hcDZ6w6Hzswe04K1N3DLODlL3b7bCmiEM2J6
