alfadriver
alfadriver MegaDork
1/13/20 1:08 p.m.
never mind 1
alfadriver
alfadriver MegaDork
1/13/20 1:11 p.m.
never mind II
alfadriver
alfadriver MegaDork
1/13/20 1:14 p.m.
I should just delete the previous posts, but IMHO....
In the core engine coolant circuit, the same one that goes to the interior heater, two oil-water coolers should be used- one for engine oil, and one for trans oil.  Both of them are quite happy running at 195-230- which is the typical range for coolant temp.  And by keeping separate coolers out- there's more space for even airflow to the radiator.
Just let the water do most of the cooling work.  Warms up fast, which will warm up the engine oil and the trans oil fast, and the heat rejection if the big radiator is quite good.
Knurled.
1/13/20 1:21 p.m.
alfadriver said:
frenchyd said:
Dusterbd13-michael said:
Separate coolers. With thermostats.
Wrong!!!!!!!! Cold oil or transmission fluid will arrive at a stable temperature when combined with coolant.  Cold oil is thick oil and takes longer to get to critical spaces same with trans fluid.
On race cars they are separated for packaging purposes  and carefully brought up to temperature prior to  use. Maybe even preheated separately.
The radiator stays at ambient temp until the coolant thermostat opens up.  Which means the trans is running ambient temp for a very long time- and that is doubly bad at -20 when the T-stat barely opens- so the trans is constantly being cold to -20.
If the trans cooler just used raw engine coolant, that would be better- since the trans likes being 200F.
In the radiator, though, it's whatever it is in the radiator.
I never paid attention much to other manufacturers' TCC strategy, but it became very apparent after installing the 4000rpm stall speed converter that Volvo does not engage the torque converter clutch until the trans fluid comes up to temp.
At least the loose converter ensures that it comes up to temp VERY quickly.
I never paid attention to the cooler topographics, but my S40 was air cooled only for the trans.  Oil cooling was via a water heat exchanger bolted to the oil pan, no external oil lines.
A lot of manufacturers are putting the trans cooler on the trans and just routing coolant to it.  Your post brings to light that this WILL warm up the trans fluid from cold, since the hoses are generally from the heater circuit.
alfadriver
alfadriver MegaDork
1/13/20 1:45 p.m.
In reply to Knurled. :
FWIW, it's just an opinion.  Not that the company I work for does anything logical like that....
Knurled.
1/13/20 2:36 p.m.
In reply to alfadriver :
Ford did something extremely logical in hindsight for the 6.7 trucks - water cooling for everything, moving the water to the heat exchangers mounted where it was convenient for them, instead of a tangled forest of plumbing and a cooling stack 12 inches thick.
Kind of like when Dodge realized, hey, we can make the radiator 40% smaller if it didn't have a bunch of stuff in front of it, so let's put the radiator here and the condensor and fluid coolers next to it...
Brett_Murphy
1/13/20 3:46 p.m.
MrChaos said:
See 2005-2008 nissan xterra/frontier/pathfinders. Many a replaced transmission.
Nissan put in bad radiators those years. You never heard about the 2004 and earlier Xterras constantly having issues mixing the coolant and trans fluid, but they all used a combo engine coolant/transmission fluid radiator..
bobzilla
bobzilla MegaDork
1/13/20 3:56 p.m.
On the wife's truck, I had external p/s and trans coolers installed with a hitch. Part of the deal I put together. The ONLY issue we've had in 13+ years is when it's idiotically cold (-15 and lower) it takes about 20 minutes for the trans to get warm enough to lock the converter at highway speeds. But I like having them seperate. Blow at trans? No problem replae the cooler.
Stampie
Stampie GRM+ Memberand UltimaDork
1/13/20 5:14 p.m.
Something has been nagging me in the back of my head. These look like my radiator actually has an oil cooler in it.
For some reason I'm thinking I plugged them when I pulled the 6.2 and put in the 350.
SVreX
SVreX MegaDork
1/13/20 5:25 p.m.
In reply to Stampie :
They work better with fans. Debate me.
Stampie
1/13/20 5:36 p.m.
In reply to SVreX :
They work just fine with leaf blowers in the staging lanes. Technically a fan just not mounted on the car.
Knurled.
1/13/20 6:37 p.m.
Usually the passenger side is the trans cooler and the driver side is the oil cooler, because Hydramatic transmissions have the trans lines on the right side and Chevy engines have the oil filter on the left side.
That said, Buick Grand Nationals had a weird setup where the oil and trans coolers were both on the right side.  The trans cooler lines snaked around to a set of fittings on the front of the radiator, requiring some hard to find right angle fittings.  And an extremely hard to find radiator, IIRC only Modine made them aftermarket and they got hoovered up by LKQ and their product lines discontinued.  An F body radiator physically fits the car, and when you go to a roller cam you can delete the oil cooler.
Stampie
1/13/20 6:46 p.m.
You know I'd agree with you normally except this one has trans lines on the driver's and the RV donor also had oil lines on the passenger. IIRC the junkyard Gen V had oil on the driver's side.
Curtis73
Curtis73 GRM+ Memberand UltimaDork
1/13/20 8:04 p.m.
Yup.  I almost always get a radiator with the circuit even if it's not used in my application.... unless it's considerably more expensive.  Never know if there will be some fluid I want to warm up or cool down.... PS return, oil, blinker fluid.
There were some years of manual GM trucks that had the trans fluid cooler circuit in the radiator with plugs in it just like that.  Same exact radiator, just assembled with the tank that has a circuit in it.
thatsnowinnebago
thatsnowinnebago GRM+ Memberand UltraDork
1/14/20 1:06 a.m.
My manual miata's radiator has a integral transmission cooler too.
mazdeuce - Seth
mazdeuce - Seth Mod Squad
1/14/20 6:56 a.m.
My wife's FJ radiator has a trans cooler built in as well, but with a manual transmission it's not needed. I'm going to use it to plumb a back country shower one of these days.
Knurled.
1/14/20 7:18 a.m.
I did say usually smiley
Generally, aftermarket radiators have the cooler, just to cut down on part numbers.  OEMs can shave a couple cents because they know how many of each type the will need.
LifeIsStout
LifeIsStout GRM+ Memberand Reader
1/14/20 10:35 a.m.
When I had my 99 4Runner (with an automatic transmission), one of the regular mods was to put in a trans cooler instead of running the combo radiator/trans cooler as the design would allow for a breakdown internally and then you have trans fluid mixing with the radiator fluid.  It's fairly prevalent and known as the 'pink milkshake' issue and will kill a transmission super quick.  When I bought the truck, I immediately replaced the radiator, but did go OEM and didn't do the separate cooler, just for money purposes at the time.
m147JCQ940I2tkxIFK7hP5vMDH1LgHiyYp6Z0Fti6W5yCGqpIwRIM8NZx5rzyptT
