granth
granth New Reader
4/2/09 3:37 a.m.
Anyone use one of these Deka ETX20L
It's the same battery as the "braille racing battery" although they will deny it. See beleow, do you need to keep one of these on a battery tender for a tack car that gets used maybe once a month?
Deka ETX20L same as Braille 15lbs http://www.jegs.com/i/Braille+Auto/147/B2015/10002/-1 $159.99 plus ship $10 No-Weight" Racing Battery 6.8'' (L) x 3.3'' (W) x 6.1'' (H) 425 Cold Cranking Amps 574 Cranking Amps 1067 (PCA) Pulse Cranking Amps
ETX20L DEKA PowerSport Battery http://www.tristatebattery.com/product_info.php?cPath=36_96_235&products_id=981 $69.95 Free ship Length: 6.8 in. Width: 3.44 in. Total Height: 6.12 in.* CCA: 270 Ah: 17.5 Weight: 15.5 lbs.
John Brown
4/2/09 6:44 a.m.
I always use powersport batteries.
DILYSI Dave
DILYSI Dave SuperDork
4/2/09 6:58 a.m.
After going years without a battery tender for the race car I got one for Christmas. I love it. My jump box is getting lonely.
Dr. Hess
Dr. Hess SuperDork
4/2/09 8:39 a.m.
"I've Heard" that Deka makes the Harley OEM batteries. That battery you listed at Jegs looks identical to the "glass mat" battery I bought for my bike last year at the stealer. Same price too. The color is different. If the second link is the same battery, that's a bargain.
Kramer
Kramer Reader
4/2/09 8:42 a.m.
Deka (actually East Penn) makes very high quality batteries. I'm not sure if they actually make this particular item, but if they do, it will be as good or better than anything else on the market.
Paul_VR6
Paul_VR6 New Reader
4/2/09 8:43 a.m.
I use a 14L in my car, I charge it before I drive it after the winter. It doesn't seem to have developed a memory at all from discharging though. Doesn't even get all the way down, just not enough to crank the car. Much better then the wet cell lawn mower one I had before.
John Brown
4/2/09 10:00 a.m.
I have a battery tender attatched to a "light minder" that charges the battery over the winter.
Best $80.00 ($24 charger, $6 timer and $50 battery) I ever spent.
granth
granth New Reader
4/2/09 10:35 p.m.
Went to CostCo tonight and they have a Honda battery (WET) for $56 and its about 27lbs, so 11 more than the Deka but it has 500CCA. It's cheap so what is 11 lbs worth? By the time you get the termainls and the AL mount for the Deka it would have been about $160 or so.
Paul_VR6
Paul_VR6 New Reader
4/3/09 8:05 a.m.
I just used two pieces of 3/8 allthread and a piece of scrap alum to hold mine down. You cant mount the wet batteries on their side either.
Josh
Josh Reader
4/3/09 9:45 a.m.
Terminals to convert flag to automotive posts are $6 for a pair at NAPA. If you're on this website, you should be able to figure out a way to get it secured for less than $94 .
CLH
CLH GRM+ Memberand New Reader
4/4/09 12:31 p.m.
I put a Deka ETX20L in my '89 RX7 a while back when I did a battery relo to the bin behind the pax seat. Paid $76 shipped from a vendor on eBay. Excellent quality, light weight, never had a problem with it. I did compression testing prior to selling the car, and the little Deka cranked it over repeatedly like a champ even though I was worried that it might drain quickly. Highly recommended, especially considering the price difference compared to the 'B' battery.
Just as an FYI, you need to be diligent when comparing CCA ratings between battery vendors...if they're using different definitions of 'CCA' the results won't be directly comparable.
Cheers,
Chris
PqWrMhYfL13Tu4SqlQc7zyvzvbmKBOKSlXm3TNm9Zr2LjLSD0RR6BJXTfOtEozdR
