mke said:OHSCrifle said:Seems like a long shot but not impossible. If an old cam is the right length and generally bigger, why couldn't it be re-ground to a smaller physical shape? It's just a piece of metal, and getting something from a junk yard and whittling away on a mill or lathe using your own labor seems like the definition of Grassroots.
In theory sure, but the odds of having metal to cut everywhere you need the metal is pretty much 0%. You need 2.5-3" OD depending on the engine the cam is going into. I used 8620 rods but if you had your heart set on iron you could by iron rods instead of steel and succeed. Making functional engine parts is pretty hard......
mke you are right. It wouldn't be easy. The stock cams aren't exotic and as the picture shows very big. I'm accepting the practical limits dictated by the engine.
Lift over .500 at the valve can't be achieved without complete re-engineering.
Besides what you've achieved with your Ferrari was already tried by the Jaguar factory. They put a 4 valve set of heads on the V12 and didn't find enough improvement on the race track to go further. The added weight on top of the engine offset any power gains.
On the Jaguar V12 it's relatively easy to do. The Six cylinder 4 valve head was designed after the V12 so it practically bolts on. ( well one side you have to turn it around, put the cam drives on the other end )
