rustybugkiller
rustybugkiller Dork
8/23/23 9:46 a.m.
I finally got both diff fluids on my frontier replaced a couple weeks ago. Today I found the rear pinion seal leaking. Could the valvoline I put in instead of Nissan fluid caused this or just the seal was due? It's the correct spec fluid.
bobzilla
bobzilla MegaDork
8/23/23 9:57 a.m.
Did it cause the leak? No. Did changing to fresh fluid so the junk came free of the seal allowing it to leak? More likely
Curtis73 (Forum Supporter)
8/23/23 10:18 a.m.
Did you pull the cover, or did you suck out the old stuff with a tube?
If you did the tube, you likely drew a small vacuum which could have been enough to move the seal.  I've seen it happen, and the common theory is that the seal pulls in a bit, and brings some of the crud from the yoke with it resulting in a leak.
If not, bobzilla hit the nail on the head.  It's the same reason for the wive's tale of switching to synthetic motor oil causing leaks.  Old-school cork gaskets would get packed full of crud, and the increased solvency of the synthetic dissolves the crud, allowing leaks.
rustybugkiller
rustybugkiller Dork
8/23/23 1:12 p.m.
Thankfully, There is a drain bolt at the bottom of the diff.
rustybugkiller
rustybugkiller Dork
8/23/23 1:27 p.m.
Replacing that seal is not that hard but getting the pinion nut back to the original position???
DIY or professional job?
APEowner
APEowner GRM+ Memberand UltraDork
8/23/23 2:37 p.m.
Mark the clocking of the nut with a punch and count the exposed threads.  Remove the nut, change the seal and put the nut back where it came from.
Xp6atuHqiB9hLoOdB5F2Ph6iv88lidSE477ekI9otpIlQfLddUx7SDC8FAVsRpRI
