Klayfish
Klayfish Reader
4/2/11 11:56 a.m.
I was about to empty the tanks of both of my old Fiat Spiders. Neither car has run in about 6 or 7 years, maybe 8. When I drain the tank, how do I properly dispose of the old gas? I assume it's no good, so I can't use it.
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
4/2/11 11:58 a.m.
Bonfire!
stuart in mn
stuart in mn SuperDork
4/2/11 12:01 p.m.
Most parts of the country have provisions for hazardous waste disposal, without knowing where you live I'd suggest checking with your local waste disposal or city government. Another possibility is to do a search using this website: http://earth911.com/recycling/hazardous/
Depending on how bad the gas is, you may be able to use it up in your regular car - just mix in a gallon with each tankful of fresh gas and it will be gone pretty soon.
jimbbski
jimbbski Reader
4/2/11 12:03 p.m.
IF you filter it first and mix it with new gas you should be able to burn it in any gasoline engine. I would prefer a lawn mower or something similar.
peter
peter Reader
4/2/11 12:03 p.m.
Are your yard implements less picky about fuel? If it hasn't turned to varnish, you could use it in those.
Giant Purple Snorklewacker
4/2/11 12:21 p.m.
I agree with the whole mix and use in yard implements although I've never tried it with anything that old. I've mixed 3yr old gas with two stroke oil and run chainsaws & weedwackers though.
Grtechguy
Grtechguy SuperDork
4/2/11 12:25 p.m.
fasted58
fasted58 Reader
4/2/11 12:26 p.m.
92CelicaHalfTrac wrote: Bonfire!
Yup, throw the old fuel on the tire pile n light 'em up on Earth Day.
Dr. Hess
Dr. Hess SuperDork
4/2/11 6:09 p.m.
Put it in your DD.
NGTD
NGTD HalfDork
4/2/11 8:40 p.m.
1/2 and 1/2 with new and into the lawnmower or snowblower.
fornetti14
fornetti14 GRM+ Memberand HalfDork
4/3/11 7:25 a.m.
Yep, lawn mower or snow blower. Works every time.
pilotbraden
pilotbraden HalfDork
4/4/11 9:18 a.m.
I have put 4 year old gas into my Miata and RX-7 a gallon or 2 at a time. It worked fine.
turboHLS30
turboHLS30 New Reader
4/4/11 10:32 a.m.
Have some annoying tree or weeds around your house? Pour it on them and give it a week or so and thet'll be gone.
16vCorey
16vCorey SuperDork
4/4/11 10:59 a.m.
I just top off my lawn mower or DD if I've got 3/4 tank of fresh gas in it already.
fast_eddie_72
fast_eddie_72 HalfDork
4/4/11 11:06 a.m.
I saw an ad on craigslist with someone giving away old gas. They said some... I dunno. Something about diesels and they like to add a little gas to it for some reason and old gas is fine for that?
Meh. Worth a shot.
tr8todd
tr8todd Reader
4/4/11 11:25 a.m.
You'd be surprised how fast it evaporates on a hot day layed out on cookie sheets, oil catch pans, newspaper, etc.
Klayfish
Klayfish Reader
4/4/11 11:27 a.m.
Interesting to hear the replies. I'd have guessed that with gas that is 7-8 years old, nobody would recommend using it in any combustion engine, even if mixed with fresh gas. Wouldn't it be pretty goopy by now?
NGTD
NGTD HalfDork
4/4/11 11:58 a.m.
Klayfish wrote: Interesting to hear the replies. I'd have guessed that with gas that is 7-8 years old, nobody would recommend using it in any combustion engine, even if mixed with fresh gas. Wouldn't it be pretty goopy by now?
Briggs and Stratton powered lawnmowers and snow blowers would just about run on urine I think. Mixed with a little fresh gas I wouldn't hesistate like I said earlier. All of the volitiles would be out of it so the fresh gas helps with stsrting etc.
I wouldn't put it in a car though.
914Driver SuperDork
4/4/11 12:25 p.m.
Add 1 gallon of old to every fill up on the DD.
Brett_Murphy
Brett_Murphy GRM+ Memberand Reader
4/4/11 3:48 p.m.
Plus one on filtering it using a coffee filter and then putting it to use.
However, after trying to use 7 gallons of gas in a lawn mower, I wound up using the last 4 gallons in my daily driver. I only have half an acre, though.
Karl La Follette
Karl La Follette Dork
4/4/11 5:34 p.m.
put in old five gal plastic can set by your curb watch it disappear, keep daughter inside during this process
simplecat
simplecat New Reader
4/5/11 3:45 a.m.
I've been running my lawnmower for about 2 years on 5 gallons that came out of my old accord's tank when i swapped the pump. I have a pretty small yard lol. The mower doesn't seem to mind.
digdug18
digdug18 Dork
4/6/11 12:30 a.m.
storm sewer...
Opus
Opus Dork
4/6/11 2:12 a.m.
digdug18 wrote: storm sewer...
Here in CA, that is a hefty fine if you get caught dumping it in the sewer. I have used it as week control at a house I was renting, but do not recommend this as the odor lingered for quite a while. If you can use it in a lawnmower or similar, go for it. If older carb vehicle, mixed in small amounts may be OK, but my Dirt bike does not like it one bit. As for Diesel, I have seen an owner of a BMW diesel (before they were imported here) put 2 gallons of super, 1 qt of marvel mystery oil and top off with diesel at least once a month. I was kinda surprised that his oil was not black (like most diesels) but looked like most gasoline cars when I had to check it.
xy0ZTWq7lokNeFP6KO2K7XCJh8wqJwfXfwMaNGbu0ckjn2WlnneikILIgKNIGe38
