singleslammer
singleslammer Dork
10/26/13 8:11 p.m.
I have a 63 Willys Jeep (courtesy of John in Kansas) that I have been trying to figure out what to do with it. The body is pretty much toast. I have this crazy idea to build a Forward Control tribute. Anyone ever seen this done before?
10/26/13 8:17 p.m.
There are two I can think of, a life-size Tonka replica and a DIY COE that's been kicking around on Craigslist for waaaaaay too much money. Anything's possible with enough money and/or effort...
ebonyandivory
ebonyandivory Dork
10/26/13 8:23 p.m.
Flat bed VW Transporter/Jeep chassis? [URL=http://s265.photobucket.com/user/derekrichardson/media/Mobile%20Uploads/image-1.jpg.html][/URL]
ebonyandivory
ebonyandivory Dork
10/26/13 8:53 p.m.
http://www.allpar.com/cars/concepts/jeep/FC.html
singleslammer
singleslammer Dork
10/26/13 9:51 p.m.
Maybe I can use a cab from a Ford Coe or something and graft in a jeep grill?
stuart in mn
stuart in mn PowerDork
10/26/13 9:59 p.m.
Is the chassis of a regular Jeep essentially the same thing as an FC Jeep? Assuming it is you'd have to re-engineer the foot pedals, and tip the steering box up.
singleslammer
singleslammer Dork
10/26/13 10:34 p.m.
No idea, I just started thinking about this today.
ditchdigger
ditchdigger SuperDork
10/26/13 10:39 p.m.
Almost any suitable cab donor is going to cost more than an FC Jeep would. A clean VW double or single cab is worth 20K. I watched an FC jeep sit on CL for months at $1200
singleslammer
singleslammer Dork
10/26/13 10:54 p.m.
Oooo what about the front third of a dodge van? I have access to one. Not quite COE but close.
singleslammer
singleslammer Dork
10/26/13 11:07 p.m.
Damn those vans are WIDE!
oldopelguy
oldopelguy Dork
10/26/13 11:28 p.m.
Any 40's cab will work, you just have to section the grill to bolt it to the firewall and make it tall enough to cover the front of the frame when you mount the cab above the engine. Use a set of Ford or Dodge step side fenders under the cab over the wheels. Bonus points for channeling the body or chopping the top while you're at it, though in this application chopping the body and doors might be better than the window posts.
I've actually gotten as far as laying out the masking tape on a second Gen s10 to cut the wheel opening out of both front fenders and the center half out of the hood to mount the grill to the cab for a cab over. I think it would work but I wish I could get a good PhotoShop to make sure it wouldn't look awful first.
Lastly, plenty of Isuzu NPR cabs around too, if you want easy...
singleslammer
singleslammer Dork
10/27/13 12:03 a.m.
Good thought on the NPR. I hadn't thought about those. Not necessarily pretty but at least functional.
On the Dodge van, I think I could use the drivers section and doors, trim the front fenders to meet up with the Willys grill and filling the holes with flat metal. Section the rear part of the van and weld to the b pillar. Could work...
iceracer
iceracer UberDork
10/27/13 10:56 a.m.
stuart in mn wrote: Is the chassis of a regular Jeep essentially the same thing as an FC Jeep? Assuming it is you'd have to re-engineer the foot pedals, and tip the steering box up.
Yes
iceracer
iceracer UberDork
10/27/13 10:58 a.m.
Later models had a wider track.
psteav
psteav GRM+ Memberand Dork
10/27/13 11:19 a.m.
Watch CL. I've seen three "real" FC jeeps go for less than $1k in the last year in various states of project-ness, all within two hours drive.
bgkast
bgkast GRM+ Memberand HalfDork
10/28/13 1:58 p.m.
I thought FC jeeps were very rare and expensive.
ClemSparks
ClemSparks PowerDork
10/28/13 2:08 p.m.
Buy that Hillman Husky or whatever that's been floating around our CL lately. WIN!
Or...you know where there's a dodge van ripe for the cuttin'.
However, my sincere vote is to just fix the body you have. It's flat metal...should be easier to fix what you have than adapt stuff you don't.
Nashco
Nashco UberDork
10/28/13 2:28 p.m.
ebonyandivory wrote: http://www.allpar.com/cars/concepts/jeep/FC.html
I'd absolutely love to build one of these. I learned about it earlier this year and fell in love. That would be a really fun build, and one that I wonder if there's a market for if there was a kit out there. Somebody else should start offering a kit before I'm forced to...
/threadjack
Bryce
ArthurDent
ArthurDent HalfDork
10/28/13 2:53 p.m.
How about a stubby nosed YJ or similar?
fordward control yj
Ian F
Ian F UltimaDork
10/28/13 3:02 p.m.
From what I remember from various articles and books, they are essentially the same with modified controls. I'm not sure the steering box is even changed, but they just added a u-joint and/or re-angled the steering column.
Dig up some books on old Army Jeeps. They are pretty well documented.
I wonder if JC Whitney still sells replacement body tubs and parts... I remember that used to be a large section in the catalog.
iceracer
iceracer UberDork
10/28/13 5:06 p.m.
There is quite a few differences between Army Jeeps and CJ's. Rear axle, transmission, electrics, wheels and tires etc. The FC 150 was on a basic CJ5 chassis with mods. With the dog house removed, the engine was readily accessible.
iceracer
iceracer UberDork
10/28/13 5:08 p.m.
Oh, I forgot the counterweight mounted in the rear.
bgkast
10/28/13 6:05 p.m.
ArthurDent wrote: How about a stubby nosed YJ or similar? fordward control yj
That almost works, the cab needs to move 6" or so forward.
Ian F
Ian F UltimaDork
10/28/13 8:46 p.m.
In reply to iceracer:
Details, details... but if he's starting from a bare chassis the books should give him an idea of how the originals were built and moving everything forward. I remember seeing some Army based FC versions, although I've seen more civilian versions.
qauOmoacXyBA9PlgiDZ93GJgGcUIgkotR0X9ZvrgYWWKW5lsn43ddRyYGGAlMq7h
